350 blocks
I have a 73 350 motor, how can i tell if it's a 4 bolt or disired block? Right now it's too greasy to touch, so where and what do I look for? Fondling around dirty things is not my favorite.
Re: 350 blocks
There should be a casting number on the back of the block, I believe there is one on the front by where the alternator mounts as well.
#3 | |
Re: 350 blocks
As long as you are not intending to rev it's guts out, it doesn't really matter.
A 2 bolt block will stand up to the average performance build just fine. As long as the block is solid and not execssively worn, it's good to go.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right.
Re: 350 blocks
I would say just pull the oil pan and check the mains.
Plays with trucks
Re: 350 blocks
Check the casting number (passenger side back of the block). If it ends in 010 it's either a 4 bolt main or heavy duty 2 bolt main. Either is a good starting point if it's not been overbored by .060 yet.
Gary My Dad's Old Truck 1985
resident wrencher
Re: 350 blocks
010 i beleive is the code for a 350 it wouldnt telly you main bolts or any thing there should be other castin marks and or stampings showing nickle content and main bolts and all that good stuff
Re: 350 blocks
Look for 010 and/or 020 under the timing chain cover, they're the better blocks, either 2 or 4 bolt. As long as it's a daily driver and not beat hard, a 2-bolt is fine. If you like driving it like you bought it at Harbor Freight, you best start with a good 4-bolt block. Gotta pull the pan, there are no single 350 castings from this time that tell if it's 2 or 4 bolt other than 400's.
78K & 79C Jimmys
Re: 350 blocks
my 78 jimmy isn't (stock 305) but it's supposed to be "period correct" 350 with 4 bolt mains
this is what the back looks like and the front numbers you can usally blast back there with a pressure washer to see them
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
| Bookmarks |
