Old 08-28-2011, 07:07 PM   #1
danleaman
Not new but still have a question
Got a 72 C 20 camper special or custom camper and was wondering if there is a difference in the rear suspension from a "regular C 20 and camper special
C-20? It's a leaf spring truck.
Thank you suspension gurus!
Dan
danleaman is offline   Reply With Quote
Old 08-28-2011, 07:45 PM   #2
wilbilt
wilbilt's Avatar
Re: Not new but still have a question
My SPID lists "G50 - Heavy Rear Spring", but that's likely the only difference as far as the rear suspension goes.
It also has a rear swaybar, but it is aftermarket.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 08-28-2011, 07:54 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
Going by the data for 1969,assuming it's the same, the minimum requirements for a leaf spring custom camper were 1) Front stabilizer bar,2) HD rear springs (G50) 3) HD front shocks (F52) and upgraded tires.
There was a 2,000 (each) leaf rear standard on Longhorns. The G50 requirement was the 2750 lb leafs (or 3,000 coils on coil rears). On a K20 the G50 option was 2500 lbs (leaf).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
