Disk brake/power steering conversion question
I am using my 63' crossmember and control arms with 72 disk brake spindles and power steering box. I have both sets of steering linkage but am a bit confused. The idler arm is considerably different for the two and there appears to be no provisions for mounting the 72 idler arm to the 63 frame. Im guessing I will need to use the 63 idler arm but am wondering which center link and tie rod adjusters to use as they appear different. I know I will need to use the outer tie rod ends from the 72 correct?
