Old 08-29-2011, 12:46 AM   #1
65GMCFirstride
65GMCFirstride's Avatar
Generator Light
We just got the 65 GMC running this weekend after 10 months of restoration. I will share some photos soon.
The Generator light stays on while driving. I figured out from the forum that it is either not charging or it is a grounding issue. The PO installed a single wire alternator and jumped 1 and 4 on the voltage meter.
I check the voltage at idle and it was 14.1 I did an ohm test from the negative terminal to the alternator casing and it showed good continuity. I verfied continuity on the frame, block, and firewall. I assume that verifies that I have a good ground.
So, any other suggestion on what I should do. I hate to simply pull the bulb.
Thanks!
65GMCFirstride is offline   Reply With Quote
Old 08-29-2011, 01:56 AM   #2
1964c-10
1964c-10's Avatar
Re: Generator Light
im not sure what the answer is but my truck is doing the same thing, i just figured i had put a bulb back in the wrong position. my truck has also been converted to an alternator.
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
1964c-10 is offline   Reply With Quote
Old 08-29-2011, 11:14 AM   #3
65GMCFirstride
Re: Generator Light
When I review the wiring diagram, I see pink and brown wires that feed the generator light. The brown goes to the voltage regulator and the pink to the ignition. I think it has to do with the voltage regulator and the fact I have a single wire alternator. I am heading down that path. I will verify the jumper wire is working on the voltage regulator.
Anyone else have suggestions?
Thanks,
