View Poll Results: would u buy them?
yep 8 80.00%
nope 1 10.00%
jerkoffsclickhere 1 10.00%
Voters: 10. You may not vote on this poll
Old 08-29-2011, 04:10 AM   #1
cr34t3d_by_d4rkd3n
if there was a company that made....
if there was a company that made stock&shorter reinforced racing swaybar brackets that used factory frame holes would u buy them? shorter for all u bagged guys...
talkn to my machenist and he says if theres enough demand hell make them just as much if not cheaper than lmc and classics factory mounts...even give u a color choice ! hahah
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 08-29-2011, 04:34 AM   #2
juiceman650
juiceman650's Avatar
Re: if there was a company that made....
This is just for brackets right? I guess I would. As long as it helps with performance and they look good.
juiceman650 is offline   Reply With Quote
Old 08-29-2011, 04:47 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
usually it better to get rid of the a arm bushings on the sway bar and raise that portion with a heim link so as to make more solid swaybar action under load, but the front can benifit from a more solid standoff for the brackets if thats what you machining,
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-30-2011, 07:36 PM   #4
85gmcguy
Plays with trucks
85gmcguy's Avatar
Like these?
http://www.classicperform.com/Store/...ck/6372LSB.htm
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 08-30-2011, 09:47 PM   #5
SCOTI
SCOTI's Avatar
If the truck is dropped enough that you're concerned about the extension brackets hitting something, skip the brackets completely & bolt the sway bar directly to the frame.
All my trucks have had +5" front drops & not a single one has used the factory or aftermarket 'shorter' extension brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
