Old 08-29-2011, 11:06 AM   #1
chrisrip
68 disc brakes
I have a 68 that I would like to convert to disc brakes...I have an 82 donor truck, and I would like to put dropped spindles on it. Does anyone know if the 82 parts will work with any of the aftermarket spindles that are out there?
chrisrip is offline   Reply With Quote
Old 08-29-2011, 12:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 68 disc brakes
Buy 73-87 spindles and you will be fine.
BUT,... make sure you measure the width of your rotors before you order.
There are 2 different spindles.
They make spindles for HD 1-1/4" wide rotors and LD 1" wide rotors.
(heavy duty and light duty)
Keith
Convert to disc brakes.
Old 08-30-2011, 10:49 PM   #3
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: 68 disc brakes
Make sure you use the '82 center link too, then you aren't mixing the tie rod ends. The center link will bolt right up to the pitman arm just fine.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
