Old 08-29-2011, 11:27 AM   #1
this man
My balancer doesn't have a timing mark on it
how do you adjust the timing without having a timing mark on the balancer? I've heard of just turning it and listening by ear, but I'm not really experienced enough to be able to do that. Any ideas?
this man is offline   Reply With Quote
Old 08-29-2011, 11:41 AM   #2
hjewell2
hjewell2's Avatar
Re: My balancer doesn't have a timing mark on it
First go buy a TDC locater one that screws into the #1 plug hole find tdc and then scribe a line on the balancer that lines up with the pointer at (0).
Make sure your are on the compression stroke not exhaust. Thats it your done. There are different ways to do this but this is the easy way for a stocker motor.
hjewell2 is offline   Reply With Quote
Old 08-29-2011, 11:50 AM   #3
cdowns
cdowns's Avatar
TDC is the exact same place on the balancer weather the compression or exhaust stroke
the proper way is with aid of a piston stop you slowly turn by hand till it is stopped by the piston stop make a referance mark then turn in oppisit direction till you are again stopped by the piston stop make another referance mark/// dead center between those two referance marks is TDC
Old 08-29-2011, 12:04 PM   #4
hjewell2
hjewell2's Avatar
Originally Posted by cdowns View Post
tdc is the exact same place on the balancer weather the compression or exhaust stroke
the proper way is with aid of a piston stop you slowly turn by hand till it is stopped by the piston stop make a referance mark then turn in oppisit direction till you are again stopped by the piston stop make another referance mark/// dead center between those two referance marks is tdc
dont believe everything you think
Old 08-29-2011, 04:21 PM   #5
cdowns
cdowns's Avatar
i dont think i know you dont understand the concept of the crank doing two exact same revolutions for each revolution of the camshaft causeing the balancer to b in the exact same place twice
look it up /read a book about timing
Old 08-29-2011, 04:28 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I believe cdowns is correct....not 100% but that'd be my asnweraswell
John
1999 Toyota Tacoma 4x4
Old 08-29-2011, 05:27 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
it is true. Maybe he just liked the quote, I know I used it the other day.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-29-2011, 05:32 PM   #8
hjewell2
hjewell2's Avatar
360 for every 180 on the cam
Old 08-29-2011, 05:40 PM   #9
webfoot
delete
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-29-2011, 05:44 PM   #10
hjewell2
hjewell2's Avatar
yes I know how to degree a cam and set advance or retard on a cam just telling the easy most simple way without getting techy with it.
Old 08-29-2011, 05:50 PM   #11
406 Q-ship
406 Q-ship's Avatar
cdowns is correct in both how to find TDC and that the timing mark works on either compression and exhaust stroke......after all it is TDC to the crank. You can hook a timing light to either 1 or 6 cylinder becuase they are 180° apart in the firing order. I have never seen a balancer without a timing mark for a small block, I would bet the line it full of paint and crap. The ring on the balancer could have slipped too. I did work on a Big Block once that had a timing mark on the bottom engine (it had the traditional one too) it was for a motorhome chassis. No way could you see the regular timing mark with the engine running in the motorhome.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-30-2011, 10:29 PM   #12
this man
Alright. So, saying i happen to get the crank at tdc on the exhaust stroke and time the dist to that, and it's at 180* out, just turn the crank another revolution or will it be fine the way it is?
