08-29-2011, 05:05 PM | #1 |
idle issue
I have an idle issue. When the truck is well warmed up she revs to high. My idle set screw is all the way out. Could this be a kickdown problem? It is a new cable and I pushed the pedal all the way to the floor to set it? There is slack in the cable when not pushed to the floor
Any help is much appreciated |
08-29-2011, 05:57 PM | #2 |
Re: idle issue
Possible Causes:
1) Timing set too high. 2) Something is preventing the throttle from returning completely. Poorly set throttle cable? 3) Vacuum leaks, likely the mixture is set too rich also, to compensate for said leaks.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
08-29-2011, 06:33 PM | #3 |
Re: idle issue
If you have a Q-jet carb, this is usually a sign of worn thottle shaft. Sometimes a spring connected to the top, cable connection helps. But you will need to get the throttle body rebushed. Also make sure your choke is going off completely & the fast idle cam is not sticking.
08-29-2011, 07:28 PM | #4 | |
Re: idle issue
it is a QJet Rochester |
08-29-2011, 07:58 PM | #5 |
Active Member
Re: idle issue
If it was a true carb shop that did it, that should have been one of the things they check. If it's the throttle shaft, you can check it yourself by manually pushing it to see if it slows down.
08-30-2011, 05:06 AM | #6 |
Laid Back
Re: idle issue
Sounds like a vacuum leak to me!!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
08-30-2011, 07:47 AM | #7 |
Re: idle issue
I use to have a vacuum leak. I'll see if I can find a tester
