08-29-2011, 06:57 PM | #1 |
bedside removal.
So everything is unbolted and it looks like the only thing holding it on is a small spot weld in the corner from the bedside to the rear cross sill. So if I cut it off, is that all it takes? Or is there something I'm not seeing.
This is silly.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-29-2011, 07:13 PM | #2 |
Re: bedside removal.
ya the small spot weld sholud be all as long as everything is unbolted!! did you unbolt the four bolts that bolts the rear sill to the bed side??
08-29-2011, 07:17 PM | #3 |
The 4 really rusty and not all that easy to get to with any of my tools, bolts? Yes, I think I got them all.
Thanks, I will grind and see what falls off.
08-29-2011, 09:54 PM | #4 |
I've heard there are two welds on each side. One on top of the rear sill (horizonal)and one at the bottom (vertical).
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
08-29-2011, 10:01 PM | #5 |
Is there any way of marking those welds to ensure proper re-alignment when you put i back together? Like drilling an 1/8" hole through it to align them back up with?
