08-29-2011, 08:18 PM | #1 |
Steering Q's
Have had a 83 K10 for many years, pretty much sits sheltered till summer.. used for camping and abit of minor towing.
two years ago I put a mild lift in (ord's rear shackle flip) and some hd springs front/rear. About 4" running 33s. Ride is great and the height is perfect making it very capable for around the backroads in my area. But this summer I have had major steering issues.. super sloppy.. replaced the box.. pretty much everything new inners/outers pitman etc etc And after only 3 months it seems to have gone sloppy again. SO my question, is it worth the upgrade to go with a x-over steering setup, similar to the one ORD offers? Anyone have any other suggestions to make the stock push-pull system work better? I didn't think I would need a x-over system running 33s on the stock 10bolt coporate... 4.10 gearing... I do not do any hardcore wheeling / rockcrawling. Thanks in advance to anyones input!
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
08-29-2011, 09:08 PM | #2 |
Re: Steering Q's
I know nothing about steering, so of course I will offer an opinion. If you replaced your steering box and everything was tight after that, then I think you might have gotten a bad steering box, or your rag joint needs replacing. Steering boxes are pretty simple, and I have had a "cheap" Autozone rebuild for 5 years with no problems, so I think a bad box is unlikely. Unfortunately, you can have problems farther up the chain in the steering column, which is much more costly to repair, and more difficult to diagnose, and something I leave to professionals. Whenever I crack open a steering column bad things happen.
Obviously, you know how to check the suspension components, and you say that all is tight there, but... This sounds like it is worth a trip to your local front end/suspension/alignment shop for a free estimate of repairs. At least call them and describe your symptoms. If they say everything is OK under the hood, but you still have sloppy steering (especially at speed) then I suspect the steering column. I have gone through all of these parts mentioned on my squares and the most expensive and most troublesome was the steering column. Since this is not your daily driver, you can crack the column and start looking for trouble. There are places online that provide step by step instructions on disassembly and repair - but at least you will be able to identify for sure that you have a bad column, and get tips on diagnosis, even if you send the work out or buy a rebuilt. One telltale sign of a bad column is a clicking or snapping sound when turning the wheel, but you would notice that if driving with the radio off, a/c off, and windows up. You could, of course, have both underhood steering component and steering column problems, but I would start under the hood again first - cheaper to fix, especially the rag joint. One other possibility is a wheel bearing, but you can check for that easily with the front end jacked up, and the alignment guys can spot this for sure. |
