Old 08-29-2011, 08:55 PM   #1
RShaips
Best adhesive for door weatherstrip?
What do you guys recomend? I have tried several kinds in the past and have not been impressed. I have all new rubber for my Jimmy and only want to put it on once! Thanks
RShaips is offline   Reply With Quote
Old 08-29-2011, 09:54 PM   #2
Boog
laying low
Boog's Avatar
Re: Best adhesive for door weatherstrip?
3m
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-29-2011, 10:04 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Go to the salvage yard and buy a pair of '86-'96 Dodge Dakota pickup door weatherstrips, push them on, cut three inches off of the end and you are done. No glue, no mess, no fuss. If you look you can find some nice ones for under 10 bucks.... Take a Phillips screwdriver, small hammer and a small pry bar with you to get them off.
Oh and don't lose the rubber inserts where the ends of the seal fit together.
LockDoc
Leon
Old 08-29-2011, 10:18 PM   #4
jtp67-72
jtp67-72's Avatar
^^^^^ that's what i like about this forum------Always learning something
new.............thanx doc................jim
jtp67-72 is offline   Reply With Quote
Old 08-29-2011, 11:06 PM   #5
mbgmike
if you have the glue on type go buy the glue from ford. i don't have the part number. its green in color and motorcraft brand. comes in a can with a screw lid and brush. don't waste time with the stuff from 3m marketed in stores. takes too long. i am sure you will get all kinds of better suggestions but they never used it I bet
mbgmike is offline   Reply With Quote
Old 08-29-2011, 11:11 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I watched a show and they had Steele Parts guy showing that the best way to install the seals was to use 3m products and spray down the door area and let it get tacky first, then apply it to the seal and attach it to the cab and hold it in place.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-29-2011, 11:36 PM   #7
LockDoc
LockDoc's Avatar
Smitty
The only problem with that is, if you don't get it in the right position before it makes contact you may tear it trying to get it back loose to move it. Having to get it over the lip around the door opening makes it tough to do. Definitely easier with two people.
LockDoc
Leon
Old 08-29-2011, 11:46 PM   #8
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I bought 2 dozen of the clips at Office Max. And the other stuff (if it's the yellow/orange crud) at the auto parts store.
I'm gonna try the Dodge Dakota door thing next time....Sounds like more fun.
For me, the key is, "...a little at a time". "Do one door and do the other tomorrow".
YMMV, because we all want to get it all done at once, right?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-29-2011, 11:48 PM   #9
Maxxd07
Maxxd07's Avatar
Caterpillar has what sounds like the same stuff. Green in a can with a brush. I dont remember what the name is but we call it green glue. It is some wicked stuff, and near impossible to get off even your hands. Works great for weatherstripping. It also works good for gasket adhesive where you dont want the gasket to move during assembly.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 08-29-2011, 11:57 PM   #10
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
gorllia snot its yellow in color and sticks to just about everything
https://secure.cbperformance.com/cat...productid=1055
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-30-2011, 12:21 AM   #11
truckster
truckster's Avatar
I've always liked the 3M black weatherstrip adhesive. It works pretty well on gaskets, too.
truckster is offline   Reply With Quote
Old 08-30-2011, 01:28 AM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice tip Leon! I may have to look for some now.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-30-2011, 05:58 AM   #13
mbgmike
we have tried all the stuff mentioned above through the years and he asked for the best. The ford or possibly the cat stuff is the way to go. 3m is crap compared to the motorcraft. its just more popular and easily found in stores so people reccomend it.
Old 08-30-2011, 06:49 AM   #14
I've always used 3M because that's the the type of thing they do. At one time they were the ones who supplied automakers. The option was always something else inferior,going back 30 or more years. But,through this thread I have learned,from people who know what they're talking about,that there is a better adhesive (topic of discussion) and even a better weatherstrip. I use the 3M weatherstrip adhesive for all sorts of things. It's great been stuff that I always keep in my toolbox. I'll have to try that Ford adhesive.
Old 08-30-2011, 07:51 AM   #15
RShaips
Thanks for all the suggestions. I think I will try the green can stuff from Ford if I can find it. In the past I have used the yellow stuff from 3M I think and always had trouble getting it to stick and always made a mess.
Old 08-30-2011, 08:18 AM   #16
truckdude239
truckdude239's Avatar
i just bought teh pushon door seals form gmc pauls
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-30-2011, 01:22 PM   #17
my67c20
Also bought the push on ones from GMC Pauls. They worked great. Just put the seam under the sill plate.
my67c20 is offline   Reply With Quote
Old 08-30-2011, 05:01 PM   #18
docflower
Side note... why is the front 3 inches missing from the window weather strip anyway?
docflower is offline   Reply With Quote
Old 08-30-2011, 07:01 PM   #19
mbgmike
we sell the exact same seal just for info.
Old 08-31-2011, 05:52 AM   #20
That's what I'll be buying. So,it stays on just fine w/o adhesive?
Old 09-01-2011, 05:49 AM   #21
GMCPaul
Yes our push on door seals we carry install without the use of any adhesive. They can be installed, removed, & reinstalled repeatedly without problems or having to worry about them coming free on their own.
Heres a link to the page we have them on
http://www.gmcpauls.com/Pickup.htm
Part# 2660241
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 09-01-2011, 11:45 AM   #22
leddzepp
Moderator
leddzepp's Avatar
Part# 2660241
Paul @ GMCPauls
these are the best, hands down. dont even waste your time with the kind that glue on
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-02-2011, 07:14 AM   #23
Perfect for me or anyone else who plans to run a truck in primer and paint later. Perfect for all uses,as well.
Old 09-02-2011, 11:28 PM   #24
dmack91
dmack91's Avatar
Thanks Leon !!
After reading your tip on Dakota seals, I went down to the U Pick It and for a total investment of $6, I now have seals that do their job.
I actually have to slam the door shut now.
Thanks again.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-24-2013, 11:06 PM   #25
nuke82
nuke82's Avatar
Thanks GMCPaul! Just ordered a pair and I can't wait to get these things in, the glue on are a royal pain!
nuke82 is offline   Reply With Quote
