Old 08-30-2011, 01:54 PM   #1
Ridnhi
Ridnhi's Avatar
What's this roll bar from
I bought this roll bar before I know what factory roll bars looked like for the 69-72 blazers. I'm not sure if this would be proper for my 71 or if it is for totally different year. looks to be factory built. what do you think?
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 08-30-2011, 03:41 PM   #2
71jimmy
71jimmy's Avatar
Re: What's this roll bar from
That, I believe, is a factory roll bar for '73 - '75. It will work, but in my opinion doesn't look right.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 08-30-2011, 09:04 PM   #3
warbucket
warbucket's Avatar
I going to use the same one in my 72 but I'm going to remove the rear legs and bracket and make new ones to go higher on the bar and extend to the wheel well.
warbucket is offline   Reply With Quote
Old 08-31-2011, 11:22 PM   #4
rsavage
rsavage's Avatar
Don't think that there were "factory" roll bars for the 69-72's. Only aftermarket -but I could be wrong. Someone else will chip in. The most common 4 points that I have seen have the back legs bolting through the front slant of the wheel tubs.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-31-2011, 11:59 PM   #5
71jimmy
71jimmy's Avatar
Your correct Grasshopper, should have said dealer installed.
