Old 08-30-2011, 06:35 PM   #1
DBear
DBear's Avatar
Raise a 66 GMC 2wd?
Do you suspension gurus have any knowledge if and how I can raise my 66 GMC truck. It is 2wd, and I don't wanna convert it to 4wd, just raise the ride height, or raise the body and frame from the wheels. Thanks for any help you can provide.
DBear is offline   Reply With Quote
Old 08-30-2011, 08:32 PM   #2
SCOTI
SCOTI's Avatar
Re: Raise a 66 GMC 2wd?
How much lift are you wanting?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-30-2011, 09:31 PM   #3
DBear
DBear's Avatar
I was thinking of about 2 to 4 inches.....wasn't really sure.
Old 08-30-2011, 10:08 PM   #4
SCOTI
SCOTI's Avatar
Big block springs will raise it some (~2" max).
For more than that, you could go the lift spindle route for 4" lift but it takes all the required 'swap' parts to use them (lift spindles for an 88-98 1/2 ton GM). They aren't cheap though....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2011, 12:01 AM   #5
DBear
DBear's Avatar
Scoti, can you tell me exactly what I would have to buy with the lift spindles to make this happen.
Old 08-31-2011, 12:58 AM   #6
SCOTI
SCOTI's Avatar
88-98 calipers
88-98 brake hoses
88-98 wheel bearings
88-98 upper/lower BJ's
67-87 3/4 ton lower a-arms
You might also need outer tie-rods too. I'd have to research (re-read) to be 100% sure on them. Some info & answers for you....
http://67-72chevytrucks.com/vboard/s...d.php?t=469743
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
