08-30-2011, 11:22 PM | #1 |
Old member
Started another project.
Since I'm going to be working nightshift over the holliday weekend I decided to start early and work tonight on the brake caliper's. I may as well stay up most of the night since I'm going to be the rest of the week.
Got the high temp ceramic kit from O-Rileys today. Caliper Paint features Ceramic Resins for maximum heat dissipation. It wont blister, flake, crack or peel. Cleaned the drivers side and have the first coat on it. The picture is a lot more red than I thought. It's not that bright in person.Well in a low lit garage it ant!
08-30-2011, 11:25 PM | #2 |
Grandpa in the rustmobile...
Re: Started another project.
purttyy
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-30-2011, 11:58 PM | #3 |
Old member
Thanks,
Just came in from putting the second coat on. Tomorrow I will clean the passengerside before work. Then paint it the next day before work. Says to let sit for 24 hrs before driving it. So I should be able to drive it Friday night I hope. I may do the fender wells also since I have the wheels off. Clean them up some to.
08-31-2011, 11:56 AM | #4 |
Old member
Drivers side is done.
Working on the passenger side now. Got it all cleanup ready to put first coat on. I used my 4" grinder with a cup brush to clean this side. Took about 15 minutes. Sprayed it off waiting on it to dry good. Pretty easy kit to use I like it.
08-31-2011, 12:01 PM | #5 |
Looks great!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
08-31-2011, 12:26 PM | #6 |
Old member
Got the first coat on passenger side done waiting to dry and do another. I'll beable to drive it tomorrow night now. The wire brusch sure helped speed up the process.
08-31-2011, 01:37 PM | #7 |
Old member
The passenger side went a lot quicker. It's done just have to let them dry for 24 hrs.
Drivers side: Passenger side:
08-31-2011, 02:08 PM | #8 |
VA72C10
Looks good. nice work!
Looking for a 67-72 swb or blazer project in or around VA. |
08-31-2011, 05:09 PM | #9 |
nice..
08-31-2011, 05:54 PM | #10 |
Old member
Thanks everyone,
the kit was easy to use. Say's it's good for 4 brake calipers. I have over 3/4 of the paint left. I may do the back drums who knows.
