Old 08-31-2011, 10:12 AM   #1
muleys67
69 C30 redo
Hello,all. Ive got a 69 I ton flatbed that I think I would like to change to a dually pickup.What problems willI come across?Do I need to change the rear end? Ive also thought of finding a later model truck for the front disc brakes also.Im planning to use this truck for pulling a car trailer not for major hauling.
Thanks for any help. Muley
muleys67 is offline   Reply With Quote
Old 08-31-2011, 11:25 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 69 C30 redo
I know very little about these year 1 tons, but I will take you back to the top so hopefully some one else will chime in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-01-2011, 12:13 AM   #3
Re: 69 C30 redo
The wheelbase is 6" longer than a longbed. If you could find a Longhorn bed,that would be perfect. The rear axle will work,but the wheel houses will need to be widened inward (tubbed). The outer tire will stick out just a bit. Those rubber fender lips work out great...about 2".
You can swap in a complete front end assembly.
Old 09-03-2011, 08:28 PM   #4
muleys67
Re: 69 C30 redo
Thanks guys.I guess Ill leave it as is.Not much chance of finding a longhorn bed around here, so im gonna fix the flatbed.Thanks again.Muley
