Old 08-31-2011, 02:16 PM   #1
treveiger
treveiger's Avatar
Can i see you power steering pictures for a 69
Well went in today for a new power steering hose an it wasn't the one I had so im trying to figure out if I have the same set up. Please post everything of your power steering set up so i can figure this out...... Thanks guys.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-31-2011, 02:56 PM   #2
longhorn70gmc
longhorn70gmc's Avatar
Re: Can i see you power steering pictures for a 69
I don't have a picture, but on two of my trucks, the 70 and 72 Longhorns, GMC and Chevrolet here is how it looks.
My power steering fluid bottle is mounted on the passenger side fender toward the front in the little indent and the hose runs down to the power steering pump then the main line runs down to the power steering box then the return line runs back up to the pump. Normally when there is a leak it comes from the PS box, but you need to take the main line and return line off, inspect them and if they check out good, clean up the lines and PS Box and put them back together testing them all to see where the leak is actually coming from. Make sure the type of hose or rubber you use is a fuel compatible type rubber. The main line FROM THE PS Pump to the PS box already comes manufactured and speaks for itself. Good luck on this. One more thing, I have seen the PS bottle mounted on the driver side fender in other trucks in the past. It makes me think that GM had fun moving stuff around in the engine bays just to do something different on the assembly line.
To identify the line you need, try to look in the LMC parts catalog and it should show you one simular to the old one. The original one is shaped that way to allow clearance under the inside fender well. I went back and re read your post, sorry to be to talkative.
R/
Billy
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 08-31-2011, 03:16 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
This help? I dont think so but i'll throw it out there lol
John
1999 Toyota Tacoma 4x4
Old 08-31-2011, 03:48 PM   #4
treveiger
treveiger's Avatar
Thanks guys, it all helps, what I'm seeing is the PO welded a new hose end so I'm not sure what the old one looked like before an why he modded it. I'm wondering if he mixed an matched parts.
Old 08-31-2011, 04:10 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you using the original style "short" water pump?
Post '72 trucks with a "long" style water pump,... use a totally different P/S set-up.
Keith
Convert to disc brakes.
Old 08-31-2011, 04:36 PM   #6
treveiger
treveiger's Avatar
No mine is a short that I know lol
Old 08-31-2011, 04:41 PM   #7
treveiger
treveiger's Avatar
Here's a pic, what does the pressure hose look like?
Old 08-31-2011, 05:56 PM   #8
oldblue1968chevy
I had my pressure hose made up by carquest, it was perfect except that it was a tad too long...
John
Old 08-31-2011, 06:00 PM   #9
treveiger
treveiger's Avatar
What do you mean made up? Like built? How much does something like that cost?
Old 08-31-2011, 06:01 PM   #10
treveiger
treveiger's Avatar
O an why did you get it made?
Old 08-31-2011, 06:28 PM   #11
longhorn70gmc
Here is what the return line looks like, it is the middle/little one. One end goes into the PS Box and the other end gets a hose that runs back to the PS Pump. The big one is an example of the main feed line from the PS Pump. The little line is a perfect example, but the bigger one comes in different shapes and sizes.
Billy
Hub Cap Freak!
Old 08-31-2011, 07:37 PM   #12
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
When I converted to power steering 4 years ago, the local NAPA did not have the pressure hose in stock, so they made one because they also make custom hydraulic hoses. It was cheaper for them to make it. Was about $15-20 if I remember right.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-01-2011, 08:05 AM   #13
treveiger
treveiger's Avatar
I'm going out to work on it today ill try to get some picks up to see if there year correct.
Old 09-01-2011, 10:27 PM   #14
treveiger
treveiger's Avatar
Is this the correct year gear box? This is where's the problem I think.
Old 09-02-2011, 10:16 PM   #15
oldgold70c10
Who's got steelies?
My making the parts store guy look things up research has told me that the power steering box is the same 68-75. Something changed in 76 (ratio?) and around 78 or 79 (roughly) they went to metric threads for the hoses. The boxes will look the same on the outside. Once you find out what kind of threads your box has got, you can have hoses made with the right threads at each end.
My Truck Page
My Youtube Channel
Old 09-03-2011, 01:02 AM   #16
treveiger
treveiger's Avatar
The box has the o ring type seals from the 81 on up is what I figured. So I need to make a custom power steering hose and sense its a three day weekend I'm screwed until Tuesday .
