Old 09-01-2011, 08:24 AM   #1
Jemo
How to orient column shifter linkage?
I have a column shifter which has the arm on the bottom of the column for the shifter linkage. Right now in Park, the shifter arm is at 12 o'clock. Facing the cab from the front of the truck, the arm moves counter clockwise and probably stops around 8 o'clock in Low. Is this ideal?
Jeff
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 09-01-2011, 09:02 AM   #2
mknittle
mknittle's Avatar
Re: How to orient column shifter linkage?
i will look at one we have here when it gets light enough out.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-01-2011, 10:23 AM   #3
Jemo
Thanks a bunch.
Old 09-01-2011, 05:59 PM   #4
solidaxel
solidaxel's Avatar
Looking at mine from the front bumper to the cab it is at about 1:00 and moves to about 4 or 5 CCW.
There are kits available that I think you can make it work, Lokar comes to mind
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-02-2011, 12:11 AM   #5
solidaxel
solidaxel's Avatar
HOW about we change that I just went out and looked at it!!
11:00 and 7:00 pm!!!
LS 3 4L70E
Old 09-02-2011, 04:42 PM   #6
redux2redux
redux2redux's Avatar
I used a Lokar setup w/ the flexible cable connecting to a 700r4.
redux2redux is offline   Reply With Quote
Old 09-02-2011, 11:26 PM   #7
Jemo
Thanks Redux. That's the kit I intend to buy. So in the pic, the shifter is in park right? Looks like I need the arm pointed at 3 o'clock to start. Thanks.
Old 09-02-2011, 09:47 AM   #8
entourageguy
Yellow truck club
entourageguy's Avatar
is that pacific time or eastern?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-02-2011, 09:57 AM   #9
solidaxel
solidaxel's Avatar
Aahhhh, Mountain Standard Time, with NO day light savings time !!!!
LS 3 4L70E
Old 09-02-2011, 11:25 AM   #10
MrDude_1
I was looking at this the otherday online.
the solution I liked best was to connect a simple rod on that arm, and have it connect to an arm facing forward. you make connected to the shift shaft on the transmission.
when you pull "up" on the column arm, it pulls the transmission into park... make sense?
MrDude_1 is offline   Reply With Quote
