Old 09-01-2011, 10:27 AM   #1
overtimeracing
overtimeracing's Avatar
Newer Master, Older truck
Hey guys... I trying to mount a mc and booster from a mid 80's truck on my 63. I need to lengthen the push rod by 1 1/2". Any suggestions? THx...Kevin
overtimeracing is offline   Reply With Quote
Old 09-01-2011, 01:58 PM   #2
kieth
kieth's Avatar
Re: Newer Master, Older truck
i went down to Lowes, they have some threaded nuts that are long, got the proper thread for the stock end that attaches to the pedal, got some all thread, and 2 backing nuts.....worked like a charm. Kieth
kieth is offline   Reply With Quote
Old 09-01-2011, 05:21 PM   #3
J.Cagle
J.Cagle's Avatar
Pics? Im about to add my power brake booster and need to do the same thing.
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 09-01-2011, 08:08 PM   #4
GeorgeLeonard
Thumbs down "All Thread"?
Im not doing this project but would be interested to know what "all thread" is. Sounds handy.
GeorgeLeonard is offline   Reply With Quote
Old 09-01-2011, 08:36 PM   #5
redneck6
all thread is a long bolt looking rod with no head on it . it is metal rod that is threaded end to end . used a lot with turn buckles and such .
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road .
09 ford f350 cc swb 4x4 6.4l , to haul the others home .
2011 chevy hhr not mine but love the milage ..
redneck6 is offline   Reply With Quote
Old 09-01-2011, 08:48 PM   #6
walls
I would guess if you're using all thread, you'd want to use "B7". I'm not sure of the tensile strength but, if using it for brakes, regular lowes all thread may be "understrength'd"(sure, it's a word)
walls is offline   Reply With Quote
Old 09-01-2011, 09:23 PM   #7
GeorgeLeonard
Oh okay. Thanks for the reply. All thread- got it. Around here we call it threaded rod.
Old 09-02-2011, 12:11 AM   #8
Captainfab
60-66 Nut
I agree. If you are going to use any all thread on something critical as brakes, you definitely want to use B7 rod and not the grade 2 stuff found at HD/Lowes. You can also find a couple different universal brake pushrods at Speedway.
http://www.speedwaymotors.com/search...r-pushrod.html
Old 09-02-2011, 10:31 AM   #9
kieth
kieth's Avatar
will get a picture of the threaded collar later today. Kieth
