09-01-2011, 12:07 PM | #1 |
5/5 drop rubbing issues
what size tires wheels and offsets are you guys running with out rubbing the tire on the fenders at a 5 inch drops with the wheel turned?
09-01-2011, 01:19 PM | #2 |
Re: 5/5 drop rubbing issues
Im running stock rubber and I just installed a 4.5" drop on the front and I think my rim is rubbing on lower control arm at full lock
09-01-2011, 10:45 PM | #3 |
Slugish
rubbing with 255x17x50 on front with 5.5 bs'ing
think you need at least 5-4.5 bs'ing to solve that. Lot of the guys here grind down their lca's to precvent rubbing when turning sharp |
09-01-2011, 11:04 PM | #4 |
I have 15x6.5 with 4.25 BS on 215/70/15 tires 5in drop.
At first I grinded on hard turns but I took a grinder to the lower control arms and solved that problem. I do have rubbing issues on the under side of the inner wheel well. I will most likely lift the front 1in.
John 82 Chevy Silverado 350ci/TH350 |
09-01-2011, 11:30 PM | #5 |
255/45/20 4.5 backspacing. 5 inch drop. Rolled fenders and I rub on hard bumps.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
09-02-2011, 12:12 AM | #6 |
Im Starting to worry I'm running a 275 60 15x8 on the front right now I don't know the back spacing but the wheels are eagle alloys that look like AR outlaw 1's how bad do you guys think it will be? I plan on going to a 245 or 255 60 soon
09-02-2011, 04:58 AM | #7 |
Diggin The SquareLife
i rubbed wth stock rally's an a 275/60 im runing 255/60
09-02-2011, 09:32 AM | #8 |
Slots go on anything!
275/60 is a pretty big tire. Mine is right about 6" drop in the front, and a 215/70 has no problems on a 6.5" rally. I was looking at trying to fit my 15x8.5 slots on the front, but am having trouble finding anyone that has any 15" tires to try to fit it. I guess I will clean up a pair of 7's to go on the front.
Some of your rubbing might be the fenderwells, too. I have heard the 81- up fenderwell is smaller than the 73-80 ones.
1974 Jimmy- 5.3/4L80e/NP241 |
09-02-2011, 01:48 PM | #9 |
Cruzzzn' Vet
275-60 is way tooo big a tire to run on the front,lowered. 245-60 is perfect, the picture shows a 275-50 on a 15x9 rim with 4" BS with the front lowered 4", people that have rims with a 5-5.5" BS have too deep a BS which will rub the control arms in tight turns, never had any issues with mine, the pic shows a 275-50 tire which has since been replaced with a 245-60 tire, BFG quit making the 275-50's so this is the next best size
Uploaded with ImageShack.us These are the 245-60's on the same 15x9 rim. Uploaded with ImageShack.us |
09-02-2011, 01:55 PM | #10 | |
alrighty, ill pick up the 245 60 15 bfgoodrich, which is perfect since my rears are 275 60 bfgoodrich
09-02-2011, 02:36 PM | #11 |
if the tire contacts the fender will it destroy the tire or the fender?
09-02-2011, 02:42 PM | #12 |
i measured it and as it sits the tire will be 1/8ish off of the tread block on my 275 60's... geez i need smaller tires lol
09-03-2011, 12:54 AM | #13 | |
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
09-03-2011, 12:28 PM | #14 |
I have 5/5.
When I was running the 15" rallies, I had the 245/60's as noted and they did well. Agree that the 265's are too big. |
09-03-2011, 01:37 PM | #15 |
what 255/60/15 tires in front? do those rub?
1979 GMC Sierra Classic Freshly lowered 5 inches |
09-03-2011, 05:24 PM | #16 |
yea i got 255/60/15 up front no rub at all
09-03-2011, 06:18 PM | #17 |
6.0 powered square
I have 215/70/15 on mine no side to side rub but a whole lot of top of the tire to inner fender rub have little bump they would hit
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
09-04-2011, 07:27 PM | #18 |
I'm looking to drop my front 2more inch...... but how is the ride for u guys..... looking for a nice smooth ride and what shock are you guys running
2.5 front 5 rear |
