Old 09-01-2011, 01:15 PM   #1
Robznob11
Robznob11's Avatar
proportion valve?
Anyone know if a 73-newer proportion valve will work for a 72 disc/drum set up its the last pice of the puzzle I need to sort out
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-01-2011, 01:23 PM   #2
jimmydean
jimmydean's Avatar
Re: proportion valve?
When I did discs on my '69, I used the MC and prop valve from a donor '75. I don't think any of the disc/drum valves are different.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 09-02-2011, 05:07 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The oem 71-72 prop valves have only 1 front line outlet.
(since the line has a tee fitting, down on the crossmember)
The 73-87 prop valves have 2 front line outlets, with two individual lines that run to each front wheel.
The 73-87 prop valve will work,... you just have to "plug" one of the front outlet ports.
Keith
Convert to disc brakes.
Old 09-02-2011, 07:56 AM   #4
Robznob11
Robznob11's Avatar
thanks guys, fulton hu i was raised in fayette mo.
LED TAILS
