Old 09-01-2011, 09:43 PM   #1
jondancer
Speedometer makes clicking noise.?
Sometimes my speedometer makes an annoying clicking noise at my dash, anyone know what would cause this or is it normal?
jondancer is offline   Reply With Quote
Old 09-01-2011, 09:45 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Speedometer makes clicking noise.?
Cable could need some lube, i pulled mine completely out from the inside and lubed it up problem solved.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-01-2011, 09:47 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
can you make a voice record or can you mimic the click ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-02-2011, 07:27 AM   #4
jondancer
No
Old 09-18-2011, 09:46 PM   #5
jondancer
Anyone know if the 2wd trucks all have the same length cable? I'm just going to replace the cable.
Old 10-04-2011, 09:15 PM   #6
jondancer
What can you lube it with?
Old 10-04-2011, 09:17 PM   #7
chewychevy67
i used a graphite spray. worked well.
chewychevy67 is offline   Reply With Quote
Old 10-10-2011, 03:59 PM   #8
jondancer
I did this and it's still bad, my gauge needle stutters and shakes too. I think I need to replace the cable .
Old 10-10-2011, 05:15 PM   #9
D-man313
D-man313's Avatar
mines doing the same thing with brand new cable and old original speedo and housing
D-man313 is offline   Reply With Quote
Old 10-10-2011, 06:37 PM   #10
57larry
disconnect the cable from the tranny, chuck the end in a drill and see it still makes noise
57larry is offline   Reply With Quote
Old 10-10-2011, 07:11 PM   #11
dcasalena
dcasalena's Avatar
same problem here. subscribed for solutions.
dcasalena is offline   Reply With Quote
Old 10-10-2011, 07:54 PM   #12
cleszkie
cleszkie's Avatar
Your speedo head has started to go bad. It will continue to get worse until the needle starts bouncing all over the place and then won't move at all. Replace your speedo head.
cleszkie is offline   Reply With Quote
Old 10-10-2011, 08:20 PM   #13
sleepingbag
sleepingbag's Avatar
I have experienced a loud ticking noise when I had an exhaust manifold leak, sounds exactly like a ticking speedometer from the drivers seat... can you hear it under the hood?
1967 GMC 3/4 ton Fleetside
350 ci Chevy
I'd rather do it myself and spend the extra 500 dollars
sleepingbag is offline   Reply With Quote
Old 10-10-2011, 10:42 PM   #14
jondancer
No its def coming from the speedo. I just got he new cluster from LMC 1200 miles ago, hope it's not the speedo head. Is the speedo head the actual gauge?
Thanks all.
Old 10-11-2011, 01:12 PM   #15
57larry
that funny
Old 10-11-2011, 02:56 PM   #16
MusicMan70
MusicMan70's Avatar
Here let me try....(clearing troat)..Hmnnn..Hmnnn...Hmnnh...
Clik, clik, clik,clik.clik,clik,tat,tat,tat,tat,tic,tic,tic,..(improve bouncing needle)..clik,clik Boing..clic,tac, tic, Boing......I used to do voice over work. Tha tha that's all folks....a little levity ok?
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-11-2011, 05:50 PM   #17
cleszkie
cleszkie's Avatar
I believe the speedo head and gauge (face and needle) are a single unit. Is the LMC unit a remanufactured OEM speedo head, or is it a Chinese repop? Either way, LMC should replace the unit for you in my opinion.
Old 10-14-2011, 11:30 PM   #18
jondancer
I'm sorry , I bought this from classic parts USA. Waiting to hear back from them. Anyone ever delt with them on a return?
