![]() Join Date: Aug 2011
Lowering my 65
Hey fellas, I can do more searching on this subject when I get to work but I dont have much tme now and am curious. Is it just as easy as ordering lowering springs for both the front and rear of the truck? At what amount f drop would you worry about lowering shocks as well? Keep in mind I have coated Long Tube headers so they may interfere with how low I could go. Dont really want slammed anyways.
Heres my build thread, would my truck look good with 2" drop all around or should I go for 3" or 4"? Thanks a lot guys like I said I'll do my own research as well. Build http://67-72chevytrucks.com/vboard/s...d.php?t=479868 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Lowering my 65
it depends on what look you want, obviously not slammed, if you want any rake, then maybe a 2/3 would be the ticket, or a lower stance would be a 2.5/4 with spindles and rear springs.
Another option is spindles and bags for the rear, lots of choices and it all depends on what you like and are looking to accomplish.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Lowering my 65
How do these trucks sit factory? level or slight rake? I can tell on mine cause it has big mud tires on the back so it sits up high. I'd like it to sit level, would a 2"-2" drop accomplish that and be level?
IBEW Electrician-Nick 1985 C20 Silverado 1965 C-10 short fleet 1961 c-10 Apache short fleet 2005 Chevy Suburban LT 2012 Hyundai Sonata ![]() |
Re: Lowering my 65
Well, they sit with a slight rake, a 2/4 would put it about level. if you want to tow much with your truck, rear airbags would be better so you can adjust the ride height.
What I am doing is 2.5 spindles with 1.5 springs. rear air bags probably 2600's with out a tank or compressor. for yours, spindles and bags for rear, youll enjoy. since your probably going disc brakes, the spindles would work well with that too.
#5 | |
Re: Lowering my 65
On the back, do the bags go in place of the springs or do they work with them? Got a link to what you are running? Thanks
