09-02-2011, 08:24 AM | #1 |
Frames
I posted locally on CL i need a 70-72 chevy gmc shortbed frame,trailing arms, that accomidates power steering.
I already had one guy say he had a 70 frame, but it was under a 78 truck with leafs. morons. Are there any differences in the 70-72 then the newer? I know alot of guys have used newer frames up to 77 or so? I need a good frame for the stepper with PS. Mine has none. I don't want to end up with something wrong. Thanks guys.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
09-02-2011, 08:32 AM | #2 | |
Re: Frames
Doug Looking for a 67-72 short bed driver..... |
09-02-2011, 08:49 AM | #3 |
Re: Frames
I thought power steering frames were different than non for 68-72? I guess I am mistaken, I can just add PS to my 71 frame? I haven't pulled it apart yet to see if the dimple is there. But I have a 2wd PS box and pump from a 71 (I think) engine.
Thanks Glen Posted via Mobile Device
09-02-2011, 08:52 AM | #4 | |
Re: Frames
09-02-2011, 08:57 AM | #5 |
its all about the +6 inches
Re: Frames
it'll bolt on.
The frames changed dramaticly in 73. Longer wheelbase, and a major kick up directly under the cab. A 4X4 can pull it off with a custom body lift and a relocated rear axle. But a 2 wheel drive can't do it. You'll end up with a mostly custom built frame and coulda saved time just going all out and full custom frame. |
09-02-2011, 09:45 AM | #6 |
Re: Frames
This truck came into work the other day, this is on a 77 frame with power steering i guess. Nice truck!
But that is y i asked the frame questions.
09-02-2011, 11:37 AM | #7 |
the boat guy
Re: Frames
power steering box should bolt right up to your 71 frame. Po added dimple to my 67 frame.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
09-02-2011, 12:46 PM | #8 |
Just a car guy
Re: Frames
Except for the dumb looking bed! I just don't get that.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
09-02-2011, 10:40 PM | #9 |
Re: Frames
Did you verify it had the claimed frame? It would be a LOT of work to make it work under a 2 wheel drive.
09-03-2011, 07:03 AM | #10 |
Re: Frames
I did not, only going by what he said, he told me the frame was junk, and he got a 77 rolling frame for it.
09-03-2011, 07:31 AM | #11 |
Re: Frames
i wonder if he ment he had one to put under it. He'll give up as soon as he puts the cab on
09-03-2011, 09:53 AM | #12 |
Re: Frames
If he ever stops in again, i'll take some frame pictures. But he said he did all the work.
