Old 09-02-2011, 03:13 PM   #1
shiner2001
shiner2001's Avatar
Question Pic/info request...Power Steering lines for BB 72
I have no idea what I've done with my old power steering lines and need to replace them, but the off the shelf ones that come from the parts store for a big block don't fit because of the inner fender. In the pictures below, you can see how the hard line coming out of the steering gear has to have a 90* in it get under the fender, and on top of the frame there is a double clip there to hold the hard line to the frame. The engine in the truck is a 454 LS6 from a 70 Chevelle, but I figure the front drive accessories are in the same location as the big block that would have come from the factory in this truck (driver side lower). The problem I am having is more on the truck end, not the engine end of things. If anyone can snap a picture of how their lines look with a big block, both from outside and inside, like the ones below, that would be awesome. Even better, if someone can tell me which application to have the parts store guy look up to get me the right lines, that would be fantastic!
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 09-02-2011, 03:19 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Pic/info request...Power Steering lines for BB 72
The correct high pressure hose for our BBC trucks is not available. Board vendor PICKMUP had some made up a while back and was selling them. Might want to PM him and see if he still has some.
As far as the reservoir hose, I got mine at a marine store. Do NOT use heater hose for this...the P/S fluid will break down the rubber and it will "weep"
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-02-2011, 03:33 PM   #3
shiner2001
shiner2001's Avatar
The ones on LMC look like they are correct, and they are also listed as 70-72 BB. Any ideas of those are the right ones?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=128
It looks like the hard line part that attaches to the gear are bent correctly. I just wish I could find my old ones so I could have the rubber replaced and be done with it.
Thanks for the heads up on the heater hose, that is what I intended on using. Was the hose you picked up from the marine place just bulk hose off of a roll or was it for something else specific?
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-02-2011, 04:12 PM   #4
leddzepp
Moderator
leddzepp's Avatar
it was bulk hose that i bought. to my knowledge the hose lmc sells is not correct either.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2011, 04:16 PM   #5
webfoot
Ever went to a hydraulic shop and see about having some made? The NAPA in the next town over makes them right in their own shop.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-02-2011, 04:24 PM   #6
shiner2001
shiner2001's Avatar
My mechanic makes hoses, but to get the bends just right I'd have to take the truck to him. I may end up having to do that, but I'd a whole lot rather find them off the shelf. It will also be a lot cheaper that way instead of having them custom done according to him.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-02-2011, 04:24 PM   #7
shiner2001
shiner2001's Avatar
Anyone have any hands on experience with that LMC hose? What about it isn't right, any idea?
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-02-2011, 04:38 PM   #8
Lemield
Lemield's Avatar
I got my reservoir hose from a Chevelle parts supplier...can't remember who...but it was pricey....exact same as the trucks though...don't know if the other hoses are the same as Chevelle big blocks though...
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-02-2011, 05:15 PM   #9
71 super
71 super's Avatar
All of the parts house and parts venders except pickemup sell the equalivant to a sb pressure hose. If you want the correct one you will need to expect to pay. As far as I know frank is the only game in town and his parts are very high quality. The "feeder line is available through gates but you will have to find a parts guy willing to work- item is located in the rear of gates book, or you could get it from chevelle parts suppliers as the early chevelles used the same setup as trucks.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-02-2011, 05:57 PM   #10
shiner2001
shiner2001's Avatar
Is Frank PICKMUP? I pm'ed if so.
Still not sure what is wrong with the LMC one if it is formed like the one in the picture. Anyone?
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-02-2011, 07:15 PM   #11
leddzepp
Moderator
leddzepp's Avatar
frank is Pickmup. i am sure the lmc hose will work, but as stated it is not the original style, as they are no longer produced.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2011, 07:30 PM   #12
shiner2001
shiner2001's Avatar
I gotcha, I thought you meant that it just plain wouldn't work. As long as I can get it out of the gear and under that inner fender, I should be good to go. This isn't a restoration or anything, so as long as I have something functional, I'm ok with it not being original. Thanks for the info and I'm looking forward to hearing back from Frank, too.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-02-2011, 07:42 PM   #13
leddzepp
Moderator
leddzepp's Avatar
I have an SBC hose on my BBC power steering also ....it IS a tight fit under the inner fender, but it will work.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2011, 08:38 PM   #14
shiner2001
shiner2001's Avatar
Man I tried to come up with a way to make the one that I have now (I guess it's for a SB, although I bought it as a LB hose) to work, but I couldn't get it to fit at all.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 09-03-2011, 10:24 AM   #15
leh72super1500
GMC with Blue Plaid
leh72super1500's Avatar
Here are some pics of mine. Hope this helps.
Current:
1972 GMC Super Custom 1500 402 < 73K Orig MI
2015 GMC Canyon SLT(Daily Driver)
Previous:
2008 Chevrolet Colorado LT 2.9L I4
1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI
1984 GMC S-15 2.8L V6
1976 GMC Sierra Classic 2500 Camper Special 350
1980 GMC High Sierra 3500 Dually 350 4spd
1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it)
1969 GMC 910 250 I6 4spd
leh72super1500 is offline   Reply With Quote
Old 09-03-2011, 10:34 AM   #16
mikeoj
Here you go http://67-72chevytrucks.com/vboard/s...d.php?t=482627
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
