Old 09-02-2011, 04:55 PM   #1
treveiger
treveiger's Avatar
power steering gear box compatibility(what years work)
Hey guys, I have a 69 Chevy truck with I think around 86 power steering box but the pump is a 69, I found this out while trying to replace my pressure hose for my power steering(the guy welded it...). So now sense there two different fittings on those p.s. pressure lines I'm wondering what would be easiest an cheapest to make this work. I thought about switching the gearing box to a 69 but would I also need new steering components to make it work? Could I switch to the power steering pump but wouldn't I need new brackets and would the pulleys line up? Right now I'm looking at making up a custom line out of the two hoses but don't know if it'll work. Any help would be awesome.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-02-2011, 06:38 PM   #2
pbmagnet
Re: power steering gear box compatibility(what years work)
You might want to check out this. http://www.purechoicemotorsports.com...rod/prd336.htm
pbmagnet is offline   Reply With Quote
Old 09-02-2011, 06:59 PM   #3
pbmagnet
Here is something else that might work.http://www.speedwaymotors.com/O-Ring...ter,24682.html
Old 09-02-2011, 11:21 PM   #4
Captainfab
60-66 Nut
The truck power steering boxes from '69-'80 all had the SAE inverted flare style fittings. From '81 and up they have the metric size fittings with the O-ring. The pumps of course are corresponding to that. An easy fix is to remove the pump from your engine, and change the pressure fitting in the back of the pump. Be careful as there is a spring behind the fitting. Of course you will need another pump as a donor for the correct fitting.
Even though the 4x4 steering boxes are physically the same and will bolt up, the pitman arms are not interchangeable.
Old 09-03-2011, 01:06 AM   #5
treveiger
treveiger's Avatar
Thanks guys this is awesome stuff
Old 09-06-2011, 02:53 PM   #6
treveiger
treveiger's Avatar
if I switched to the later fitting would she screw right in? Thanks a lot guys
Old 09-06-2011, 04:50 PM   #7
67Slider
67Slider's Avatar
I used the pump, steering box and hoses from a mid 80's C-10. It all bolted right up.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 09-06-2011, 05:39 PM   #8
treveiger
treveiger's Avatar
I pulled the part, it looks like it'll work, ill keep you informed!
Old 09-06-2011, 05:47 PM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
One thing you really need to keep in mind if you change the gear box Plan on not having your sharp turning any longer.Auto zone gives you the cheep box and get your 350.00 box as a core.Never give up your factory gear box of you will do a lot of backing up to make a turn
stsalvage is offline   Reply With Quote
Old 09-06-2011, 05:57 PM   #10
OhOneWS6
OhOneWS6's Avatar
This is incorrect. I put a later model (Square body) gear box on mine and it still hits the physical stops on the control arm in both directions. I used the pitman arm for a 72.
OhOneWS6 is offline   Reply With Quote
Old 09-06-2011, 10:33 PM   #11
treveiger
treveiger's Avatar
O the truck turned great before so it should now I just needed the hose, I got it all up there but now I can't get the last bolt to the block in...
Old 09-15-2011, 09:12 AM   #12
treveiger
treveiger's Avatar
Well I went to you pull it an found the fitment that I needed an the newer hose went on pretty easy also. Works great now, thanks guys!
Old 09-15-2011, 09:57 AM   #13
OhOneWS6
OhOneWS6's Avatar
Glad you got it sorted out. So just to sum it up for others that may find this thread, you have a later model box with the o-ring fittings instead of flair as well as the fitting in the back of the pump and hose from a later model to match the o-ring fitting in the box, correct?
Old 09-15-2011, 11:26 AM   #14
treveiger
treveiger's Avatar
Yes I have the 80s gear box with a 69 pump. The gear box had the o ring fitting an the pump had the flared so I went to a junk yard with the old piece(to make sure the threads were the same) an took the fitting off of a later power steering pump an put it into my 69 pump, then used a 80s power steering hose.
Old 09-18-2011, 06:50 AM   #15
68C15
blood type; Retumbo
68C15's Avatar
and you never bothered to call me. I have 2 or 3 of these fittings in my box at work.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-18-2011, 07:13 PM   #16
treveiger
treveiger's Avatar
I never thought of it, I was trying to get it don't before I went to the docs so I ran all over too. Are you putting a earlier box on your truck?
Old 10-03-2011, 04:57 PM   #17
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok I have the old 69 manual steering, that takes darn near 5 turns to go from complete left to right. I say a post that from the 80's turck will work, is that true?
My problem if im in a tight space, it takes forever to manuver.
VDOG is offline   Reply With Quote
Old 10-03-2011, 06:18 PM   #18
lil hoodlum
lil hoodlum's Avatar
Not sure if this will help you any.
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
