spindle and center link?
Hello all,
I just read 50 or so threads using "spindle" in the search bar; but didn't really find the answer Sooo... I'm working on a '71 C10 SWB with power steering. Wanting to drop the truck around 4.5 front and 6 rear. I already own a set of 1973+ 2.5" drop spindles and 2" springs. It seems as though the ball joints and outer tie rods are the same for both years, so I should be able to physicaly mount the newer spindles onto the arms. Does my '72 center link pose any alignment problems using the newer spindle? Can I use the 73-87 2" drop springs in my '71 without issue? Thanks, Keith
1971 C10 SWB 350/350 A/C PS PDB |
Re: spindle and center link?
I thought the 71-72 uses a differernt balljoint and tie rod than the 73 up. I may be wrong [happens all the time] check with the parts store to be sure.
#3 | |
www.tomthetruck.blogspot.com <-- Aka build thread. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
73 and up uses different tie rod end and upper ball joint. Lower ball joint is the same though.
I'd buy a pair of upper ball joints from the parts store and the entire 73-87 steering linkage from a junkyard. Just get the whole deal from outer tie rod end through the other outer tie rod end, including center link. You can reuse your existing pitman arm and idler arm.
Hey, Thanks Guys,
My mistake. I just went to Rockauto.com and checked parts differences. upper BJ = different ('71=K6124 / '73=K6136) lower BJ = same (K6117) tie rod ends and sleeves = same (409R/ES2004S/409L) So, swap out the upper BJ and the spindle will physicaly mount to either year. Right? What I was really looking at were the springs and center link. The stock spring specs are VERY similar. The '73 spring is less than 1/2" taller and only marginaly stiffer, and both have the same installed height. 1973 C10 350 V8 RAYBESTOS Part # 5851075 Professional Grade; Sold in Pairs -- Inside Diameter=3.68" Wire Diameter=.781" Free Height=13.64" Load height=10" 1971 C10 350 V8 RAYBESTOS Part # 5851011 Professional Grade; Sold in Pairs -- Inside Diameter=3.68" Wire Diameter=.75" Free Height=13.18" Load height=10" Is it reasonable to assume the 2" lowered spring to be AS similar? Will I really notice the difference? Also, if the Pitman, Idler, and outer TRE are the same; will my existing 1971 P/S center link work OK? (I couldnt find any information on the '71 center as it appears to be obsolete) Point is here; I'm trying to work with that which I already own, if it's possible. Thanks again, Keith
I used the 73-87 spindle before. You need the ball joints and outer tierod ends for a 73-87 truck.You need an adapter sleeve to mate the tie rods.You also use your existing outer tie rod as your inner. Search disk brake conversion for more info.Good luck.
Sorry reread your post I saw yours is a 71. Your tierods should be good as is. Not sure about springs though.
