Switching to Rallys - need help
My 72 has 15x6 Weld wheels on the front and 15x10 on the rear wearing 225/75 and 315/75 tires. I want to put on some Rallys. My trouble is the truck has been set up to be level or close to it with the above tires. I have some Rallys with 255/70s on them, but the front end sits about 1 1/2" higher in the front with the 255s on it.
What size tire can I run in the front to get it back level or some rake? thought about 235 or 245/ 60 and stay with a 255 in the rear. Or do I need to lower the front of the truck more to accomodate a 255 (maybe a 60 series) in the front? Attached is a picture of the truck with the little fronts and big rears...
'85 C-10, with 93 LT-1 & 4L60 1985 GMC, lookin' for its big block motor - SOLD '72 Chevy C-10 Cheyenne-SOLD |
Active Member
Re: Switching to Rallys - need help
You would likley be better off running some coil spring spacers in the rear
I do not think you will fins a short enough tire that will still fit on ralley wheels to make up 1.5"
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
I dont have an answer for you but that is one fine looking truck ,similar to the color I hope mine turns out and mine will be running ralleys too but at stock height. I keep scrolling back up to look at that beauty .
thanks for the comments.... tell me more about the coil spring spacers!!!!
I am a Referee of life.
Nice truc k!! How was it lowered? this may make a difference in what works best/spends less.Keep in mind that Rallies are 8" so the current rear tires will be too wide for the rim.You can get aftermarket rallies that wide IIRC but they be spendy.
This may help http://www.dakota-truck.net/TIRECALC/ or this http://www.miata.net/cgi-bin/tirescgi
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Don't really know how it was lowered.. it was done in 93 when the truck was built..
i want away from the 315/75s on the rear.. i think i may need to put the rallys i have with the 255/70s on the rear and let the front down with a jack until I get the rake i like, measure to the top of the wheel well opening and figure out what front tire will work the best.... but keep the ideas rolling
I really wish BFG would bring those rear tires back. There's really a void in the market if you want a bigger tire like yours that's affordable and not a race type tire.
Anyway, I think a mean looking setup would be a 15x6 w/215's on the front and 15x10 w/285/70 on the rear.
'68 C10 SWB "Purple Nurple" |
Looks great just the way it is. Would not touch a thing.
i would put 275/60's on the rear. should be almost an inch taller than 255's. but if still not enough you could either lower front or raise rear an inch or so. i like the look you have now (what i wanted) but the wheels i bought have wrong backspacing so i had 2 stay short with 295/50 on 10 inch tt2's in rear and 235/60 on 7 inchers on front, would love to see yours on mine.
Thanks for the info and comments guys... the welds will be for sale shortly after I get the Rallys situated....
I put the Rallys with the 255/70s on her today... Tires are dirty and wheels are to be painted. Is the stance OK or does it need more rake??????
![]() Join Date: Mar 2007
Looks good to me
Big Block Powered |
#13 |
Why were you getting away from the 'current' sizes?
It looked nice (& I don't care for Welds). I would have just swapped to some ralleys in the same sizes & rolled as is or gone a little shorter tire in the rear (275-60's/285-70's).
#14 |
I am running a 255/70/15 rear 235/70/15 front combo on my burb with a 5" drop in the rear and a 4" drop in the front. I think one of the issues you might find by going to a shorter tire on the front is that the gap between the top of front fender and tire will be more on the front than the rear. The closer to the same you keep these gaps the better is looks.
IMO the back looks perfect. I suggest lowering the front and going to a 235/70. |
#15 |
I didn't like the big spread in tire sizes from front to rear and really thought the truck might sell better without the pro street look. the 315/75 is a large tire....
#16 |
Senior Moment
![]() Join Date: Mar 2002
What are you doing with the Welds?? I think they would look GREAT on my truck
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#17 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Your truck looks great with the 255/70's on it now. However if you went to a 275/60R15 on the back it would be 27.98 inches high and would fit great on on a 8 inch Rally. The 225/75 you have on the front now are 28.28 inches high which is close to the 27.98 height of the 275/60 so you could have the level look you want but you would need to find a 15 x 7 inch rally for the 225 tire. I also think this would be the cheapest way for your accomplish what you want to do.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#18 |
Eat, Sleep, Drive a Chevy
The truck looks great with the rallys, I agree that 275/60's would look good back there
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#19 | |
If you like trhe stance/Aspect Ratio, let me know, and I'll get the tire sizes I'm running and post them here for you.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#20 |
WWOTR... let me know the sizes
#21 |
when you get ready to sell the welds, let me know im in alabama..
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
#22 |
Running BF Goodrich 215-70 R15 Front / BF Goodrich 275-60 R15 Rear.
I should also mention that its lowered 5.5" in Front and 6" in the rear. Front was done with 2 1/2" Drop Spindles and 3" CPP Springs/Shocks. The Rear was done with 4" CPP Springs, Shocks and a 2" Lowering Block. Shock Relocators were also used. Hope that helps! ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 09-04-2011 at 04:32 PM. |
