Old 04-10-2003, 09:37 AM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
June Chevy High Performance SB 406
This build-up results in 525 ft-lb @ 3500 rpm and 428 hp @ 5000 rpm. It is a torque monster with 471 ft-lb @ 2300 rpm! They used Vortec heads and a Lunati 00010LK cam with .480 lift...that means you can use stock Vortec heads from the junkyard for only $150! They used the upgraded Vortecs in the build-up but stockers will handle the lift according to every spec I've read and you are keeping it below 5000 rpm so there should be no need for those expensive high rpm components! Sounds good to me to if you already have a serviceable 400. This could be a real bargain build-up.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-10-2003, 06:42 PM   #2
Low68
Low68's Avatar
I am going to have to get that magazine. I have a 400 that might still be good layin around. Maybe I will build it up and put it in an old car or something! That would be fun. Thanks for the info.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 04-10-2003, 07:03 PM   #3
trailwart
trailwart's Avatar
looks like i will have to get the mag also
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 04-10-2003, 07:28 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
525 ft-lb???
That'd be REALLY nice in my truck...of course, I'd have to go get the 700R4 beefed up some in fairly short order!
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
