09-03-2011, 08:22 AM | #1 |
Paint help, seam on 1965 swb
What does everybody do with the horizontal seam that separates the lower & upper bedside on a SWB? I feel if I seam seal it, it'll crack & not look very good, even if it doesn't crack. If I just paint it with today's high build paint (not thin laquer of years ago) it'll stick together from the top panel to the lower and eventually separate too. What has everybody else done? Any help here, much appreciated! Thanks Frank
09-03-2011, 09:17 AM | #2 |
Re: Paint help, seam on 1965 swb
I filled my seam by first drilling very small holes in the seams, then welding each hole making it one piece, then grinding the area to make seam uniform again. and like all body work bondo to fill in smooth, because it is welded together it dont move or crack. i have been daily driving my truck going on 6 years now and not 1 crack. did the same to my dads truck and he is going on about 8 years with same thing, no problems, my brother is doing a 65 longbed using same method
09-19-2011, 09:56 PM | #3 | |
What kind of luck have others have at just spraying the seam without welding or sealing the seam? Any close up pics anybody? Thanks for the help. |
09-29-2011, 12:39 PM | #4 |
Slots go on anything!
You could always use panel bond in the seam, or something similar. It's a lot easier than welding it, and should last as long.
1974 Jimmy- 5.3/4L80e/NP241 |
09-29-2011, 12:57 PM | #5 |
seam sealer ...
09-29-2011, 07:46 PM | #6 | |
I just sprayed right over that seam (no welding or sealer) when I painted my dad's 66 about 12 years ago. The paint I used was Dupont Centari acrylic enamel. It built up thicker than the factory lacquer but I didn't have any issues with it "bridging over" the seam and sticking together. I'll go take a close up pic and post it in a day or two. |
09-29-2011, 08:10 PM | #7 |
09-29-2011, 08:13 PM | #8 |
09-29-2011, 08:19 PM | #9 | |
I'm hoping to just spray the non sanding etching primer on the bare metal, then 3-4 coats of good three part primer surfacer right over the etching primer, block sand, seal, and paint it. Love to see those pics. Thank much, Frank |
09-29-2011, 10:56 PM | #10 |
I've never had a problem with 3M Fast N Firm shrinking ... never used it on an exterior panel, but have used it on interior panels that were sanded and painted without any problems.
09-30-2011, 07:37 PM | #11 | |
Here's a couple close-up pics I took today: As you can see in the first pic, the seam gets a little tighter/narrower right near the back of the bed (probably the way it got clamped/welded together at the factory). And it looks like the paint did "bridge the gap" a little bit deep into the groove in that area. It's only visible when looking straight into the seam (as in these pics) and doesn't have any cracks. Unless you really need it to smooth things out, you might want to consider using fewer coats of primer/surfacer in this seam area. If I remember correctly, I only sprayed the seam with one coat of DuPont Variprime (a sandable etch primer). |
