Old 09-03-2011, 12:40 PM   #1
94fourdoor
trans issues
ok, so i was driving yesterday, and i stopped at a stoplight. when i went to pull off, there was a loud whining noise, and the truck acted like it was in neutral. i still have 1st and reverse, but no second or third. what could possibly be the problem? i have already replaced all vacuum components, i am at a loss
94fourdoor is offline   Reply With Quote
Old 09-03-2011, 01:08 PM   #2
Rogue_Alphonse
Rogue_Alphonse's Avatar
Re: trans issues
Could be the governor at the back of the trans, but I've only seen that go once on a TH400 and all it did was not let the trans shift into first.
Mine does the same thing as yours if I stop too fast without manually downshifting or if I leave it in overdrive. Then I have to put it in neutral, shift the T-case to 4lo and back to 2hi and put the trans back in drive again.
I'll be keeping an eye on this thread for sure.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
