Old 09-03-2011, 03:47 PM   #1
jdheff1982
Question Odd engine stumble during right turns
As title says, my engine stumbles when making right turns. I am not sure why. It does not do this during left hand turns. But I usually have to bip the gas to keep it alive.
Anyone have ideas as to where I need to start looking? Thanks!
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 09-03-2011, 04:13 PM   #2
C-10 simplex
Re: Odd engine stumble during right turns
Is this carb or Fuel inject? First thing to check would be if the battery is securely bolted down? Then check positive and negative battery cables.
C-10 simplex is offline   Reply With Quote
Old 09-03-2011, 05:14 PM   #3
jdheff1982
It is carbbed. Battery is secure. Brand new battery cables installed last week. Truck has been doing this before cable replacement. All connections are secure.
Old 09-03-2011, 05:19 PM   #4
tazman87
tazman87's Avatar
power steering pump...right hand turns may be more stiff then making left hand turns. check alignment...sounds crazy i know
tazman87 is offline   Reply With Quote
Old 09-03-2011, 05:26 PM   #5
rwhit57
rwhit57's Avatar
I would say float level in he carb. If it is too low when it sloshes to one side it starves it. If it is too high it floods it. Just my guess. Edelbrock carb?
rwhit57 is offline   Reply With Quote
Old 09-03-2011, 07:18 PM   #6
jdheff1982
Ya, 1405. Think it needs new floats?
Also, ps pump could be it. As it squeels. The pi left the ad support bracket off, so the whole side was allowed to flop around. I'm thinking of replacing it this weekend.
Old 09-04-2011, 03:30 AM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I had a 73 that did that years ago, I trade'd for it just to resale. the guy that want'd it said he didnt care he was gonna replace the drive train any way. we never even try'd to figure it out.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 09-04-2011, 10:36 AM   #8
jdheff1982
Also, ps pump could be it. As it squeels. The PO left the AC support bracket off, so the whole side was allowed to flop around. I'm thinking of replacing it this weekend.
WOW! Stupid predictive text!
Old 09-04-2011, 01:25 PM   #9
C-10 simplex
If the battery and cables are ok, then yes i would also look towards the float(s).
Old 09-04-2011, 02:32 PM   #10
jdheff1982
I read thru the manual for my carb, Edelbrock suggested increasing accel. pump stroke. I tried that and seemed to help some. Still acts like it wants to die.
Tomorrow, I'll be able to tell if the PS pump is the culprit or not. Never swapped 1 before. Looks pretty straight forward.
On a side note, I made a startling discovery about the carb. I found a piece of linkage not attached on the left side of carb. I believe it connects the secondaries (please correct me if I am wrong) to the accelerator. Took it for a quick drive and it seemed to have more power.
The over-all look of the carb leads me to think that it is due for a rebuild anyways. It looks pretty rough. Not exactly an area I have any knowledge in.
