Gaskets
Does anybody know how to identify an Edlebrock manifold if it doesn't have any numbers on it?
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears 2005 GMC Yukon XL Denali w/Mangnaflow Exhaust 1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters Patriots always talk of dying for their country but never of killing for their country. |
Re: Gaskets
got any pics?
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Gaskets
I've never seen an Edelbrock intake that didn't have some sort of identifying numbers on it. I agree, pics would help.
Re: Gaskets
Unless the previous owner polished them off all elde`s have numbers, the only manfold that don`t have numbers are the performer plus ( not related to edelbrock ) made in china...junk.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: Gaskets
Here are the pics. It has the carb on it. I checked behind the carb for numbers and still didn't see anything.
Resistance is Futile
Re: Gaskets
That looks like a Torker manifold to me.....I'm sure some others will chime in. If I'm correct it was a midrange power single plane manifold.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Registered Truck Offender
Re: Gaskets
Ditto
#5001 Torker II The name is cast in the low flat in front of the distributor. Nothing there???? ![]() I've only seen one engine these intakes worked good on,, a 355 with RPM heads, mild solid flat tappet cam, 5000stall convertor, shifting at 6600. There pretty unresponsive below 3000rpm
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 09-04-2011 at 11:44 AM. |
Dino burner
Re: Gaskets
As others have said, it sure looks like a 5001 Torker II.
If all else fails, remove the intake manifold from the engine, turn the manifold upside down, and read the part number that is cast into the aluminum there. |
~Rest In Peace~
Re: Gaskets
remember edelbrocks tm1 manifolds tarantula, runners were short for high air flow 7500 rpm ,they look like a torker
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
60-66 Nut
Re: Gaskets
Yes I agree, that is a Torker !! manifold. Like has already been said, not really a street friendly manifold. You would get better performance out of a Performer RPM/ RPM Air Gap. Heck a standard Performer would likely perform better on the street.
Re: Gaskets
You are all correct!!! After I wiped the oil and dirt off I seen the torquer II stamp on it. But instead of replacing the manifold gasket I replaced the valve cover gaskets to see if oil ends up on top of the engine on the passenger side, where the valve cover was missing the gasket.
#12 | |
Re: Gaskets
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears 2005 GMC Yukon XL Denali w/Mangnaflow Exhaust 1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters Patriots always talk of dying for their country but never of killing for their country. Last edited by usmcchevy; 09-06-2011 at 12:31 PM. |
#13 |
60-66 Nut
Re: Gaskets
I really don't know what the Torker intake, nor the 305 H.O. heads would be worth. There really isn't much demand for either, so it's a situation where if you can find someone that is looking for those, to get the best price out of them. If you could get $50-75 for the intake, and maybe $50 for the heads, I think that would be about all you could expect.
#14 | ||
"I ain't nobody, dork."
Re: Gaskets
Unless you find a "305 guy"... those heads are scrap.
Clean up the Torker and huck it on CL for $100 bucks. See what ya get. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#15 |
its all about the +6 inches
Re: Gaskets
take a look on e bay and see if there are any intakes like that for sale... then keep an eye on the auction. That should get you an idea what they are going for.
#16 |
Java Mechanic
Re: Gaskets
I had a Torker II on a 350 in my 72 Camaro that worked great, of course, the camaro was a tad lighter than a truck. :P
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#17 |
Re: Gaskets
I got the performer on the Christmas list with new 350 heads(not sure which ones though).
