Old 09-03-2011, 05:59 PM   #1
65GMCFirstride
65GMCFirstride's Avatar
Neutral Switch 700r
I am installing a neutral saftey switch in my 65 GMC. I have a 700R transmission and a 72 van tilt column in the truck. I am having trouble adjusting it to "start" in neutral. It is starting in the drive position next to neutral. I have adjusted the switch as much as I can.
I started to wonder if the 72 neutral switch is for a non-overdrive transmission and that is why I am having trouble with the adjustment.
Is that accurate?
I have searched the deepest depths of the forum, but I found nothing that addresses my issue.
Thanks,
65GMCFirstride is offline   Reply With Quote
Old 09-03-2011, 08:53 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Neutral Switch 700r
I'm wondering if you need to enlarge the slot for the switch to get more adjustment. Alan's Classics build thread showed mods to his steering column but I dont remember what the mods were for exactly. 'Vitamin C-10' in builds....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
neutral switch
