Old 09-03-2011, 08:46 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Some Days It's Just Not A Good Day To Work On The Truck
I knew I should'a stayed home today. Just felt it.
Last week, I got the rear trim on. I had a little problem with the upper center trim...right over the tail gate "opener". So, as I wrote before, I improvised. I wasn't really happy with it. But, the main thing was I wasn't
real sure about trim back there anyway. So, I devised a way to use 3M trim tape instead of drilling holes for clips. That worked out really well...Maybe TOO well as it happens. Since it took me an hour to peel it all off today.
I wanted to get the center upper trim right. So, I visited our friends at ECE and they found an OEM piece in their stash. They gave me the little clips that you shove into holes...Aieeee! HOLES!!!!
Didn't want to drill holes. But I did.
Long story short.....I went caveman when I couldn't get it right. So, you see what's left now. That ball of stuff is $30 worth of 3M tape. I now have holes up by the handle and no trim.
Should'a stayed home.
The first shot's the one I started with this morning.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-03-2011, 10:05 PM   #2
Frkypunk70
Frkypunk70's Avatar
Re: Some Days It's Just Not A Good Day To Work On The Truck
Should have just left it alone or stepped away or gone for a walk. It looked fine with the 3m. I have dicked around with stuff that looked fine and ended up in that position. You can't always be a perfectionist, but if you are, have the patience to back it. Just my opinion.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 09-03-2011, 10:16 PM   #3
hayhauler71
hayhauler71's Avatar
Did you use a heat gun to warm up the trim before pulling on it? It does wonders
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 09-03-2011, 10:19 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
I think it looked good in the first pic.
May i ask why you taillight lenses are upside down?
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-04-2011, 12:15 AM   #5
magwakeenercew2jh
Hahahaha!!! When I put the tail light trim on, I was just mocking up the backup/tail lights. The first one was upside down.
So, for no real (good) reason, I put the second one on upside down, too.
I'm taking Frkypunk70's suggestion and walking away from the tailgate for a while. Just enough to see if I can get "the patience to back it" up.
I don't know what I'm going to do back there. But I do have a great way to stick the trim on now without drilling holes.
Two runs of 7/8" 3M trim tape. One sits down in the channel and "backs up" ( ) the second run. The second makes contact with
the first and the paint.
I used rubbing alcohol before sticking the trim on and let it dry very well before doing so. Never tried using the heat gun.
Sounds like a good idea.
Might go back to this.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-04-2011, 11:03 AM   #6
lil hoodlum
lil hoodlum's Avatar
I was wanting to try the same thing with the 3M trim tape for the paint divider trim for the cab back panel. My original cab had the pins to attatch the molding. My swapped cabs and the newer cab did not have the pins for the molding. I really don't want to drill holes either but I might. I haven't tackled my tailgate either. Mine is an aftermarket no holes either. I might consider using the 3M trim tape as well just like you have done.
Do you have any pointers you might be willing to share?
Keith
lil hoodlum is online now   Reply With Quote
Old 09-04-2011, 12:36 PM   #7
Kidd-7
Kidd-7's Avatar
Sorry about you're luck here, most of us have probably been in similar situations. I have to say, though, your taillights are sweet, where did you get the smoked lenses and how good does the red show through? Is it just a red bulb?
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 09-04-2011, 02:06 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
iN YOUR 3RD PICTURE IS THAT THE 3M OR WADDED UP TAILGATE TRIM?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-04-2011, 02:49 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
i don't know how his are but you can get the lense tinter at the parts store its like a spray paint.
Proverbs 3:5,6
Old 09-04-2011, 03:27 PM   #10
magwakeenercew2jh
The third pic (the one of the floor) is the trim after I pulled my Neanderthal move.
The stuff you spray on the clear lenses is called "Nightshade". There may be other brands...But I got my can of it at O'Rileys. One light coat.
I think that if you get too heavy-handed, it gets too dark pretty quick. I'm using a red "lcd" bulb in the stock socket.
I'm using it on my front parking/turn signal lenses, too (w/amber bulbs).
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-04-2011, 03:59 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Is any of the trim straight as Im looking for 4 pieces 2 inches long.
MEMBER #6377
Project "7DEUCE"
Old 09-04-2011, 04:02 PM   #12
magwakeenercew2jh
Send me your address. I'll send it to you on Tuesday.
I'll send enough for you to get the job done. But I'll let YOU cut it up.
There's plenty of straight stuff left for your 4 x 2" slabs.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-04-2011, 04:29 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
P.m./ sent thank you so much..
MEMBER #6377
Project "7DEUCE"
Old 09-04-2011, 04:36 PM   #14
magwakeenercew2jh
Got it. On its way on Tuesday.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-04-2011, 04:36 PM   #15
Hubscrub
Cruzin
Hubscrub's Avatar
them lenses do look good how bout a full truck pic?
Proverbs 3:5,6
Old 09-04-2011, 05:05 PM   #16
magwakeenercew2jh
Don't have a full truck yet!!!! Still a pile 'o parts.
Almost ready to put the front clip back on.
New grill coming next week. Bleed the brakes. Fill up the trans and power steering box. Then put the front clip in place.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
