Old 09-03-2011, 10:17 PM   #1
jacklegjim
72 driveshaft question
I have a 72 lwb that has a 350 turbo trans in it. I am putting the running gear
from the 72 lwb on a swb frame and will be useing a 400 turbo trans out of a 77 c20. The yoke on the 400 is bolted to the output shaft to keep it from moving in and out. Can I just take the bolt out of the yoke and cut the front driveshaft down or will I need a different shaft?
Thanks Jim
jacklegjim is offline   Reply With Quote
Old 09-04-2011, 07:28 AM   #2
JimKshortstep4x4
Re: 72 driveshaft question
You should be ok if the yoke you are using is long enough to slide in and out.
We put a transmission in a truck with the bolted yoke that the output shaft was not threaded on and it works fine. The hole in the yoke was closed to prevent leakage.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-04-2011, 11:34 AM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
I'd have a one piece driveshaft made with a th400 slip yoke
brad_man_72 is offline   Reply With Quote
