Old 09-03-2011, 10:34 PM   #1
super68c10
need help
how do i pull my ignition switch out? is there a trick or is mine just stuck?
i un screwed the face for about five turns and then it got really tight?
super68c10 is offline   Reply With Quote
Old 09-03-2011, 10:37 PM   #2
454stepside
Re: need help
you must pull the key cylinder out first and to do that you will need a paper clip bent straight turn your ignition into accesory position insert paper clip into hole on front of key cylinder and push in as far as it will go and turn key past accesory as your pulling lock cylinder out then you can unscrew the bezel
454stepside is offline   Reply With Quote
Old 09-03-2011, 10:38 PM   #3
dcasalena
dcasalena's Avatar
Re: need help
turn the key to acc (left) then stick a paperclip into the little hole in the key tumbler face. the tumbler should then pull out and then the bezel will spin the rest of the way off.
dcasalena is offline   Reply With Quote
Old 09-03-2011, 10:39 PM   #4
dcasalena
dcasalena's Avatar
Re: need help
454 beat me to it.
Old 09-03-2011, 10:45 PM   #5
454stepside
Re: need help
and i type slow with two fingers lol
Old 09-04-2011, 08:18 AM   #6
super68c10
Re: need help
thanks alot guys, i knew that lil hole had something to do with it
i guess i dont have to tell yall im a virgin at this ill start a build thread when i get some pics
Old 09-04-2011, 09:28 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: need help
it can be a real pain in the 12 bolt to get out. Sometimes you have to wiggle or jiggle, and hold your tongue just right as you spew 4 letter words.
Then you'll go have a smoke (even as a non smoker you may want one) and when you come back and try again, it'll just pop out into your hand.
Also, personally, I prefer a small allen wrench ovr a paperclip.
Old 09-04-2011, 05:15 PM   #8
super68c10
Re: need help
ok well i guess my ignition switch is messed up it will only turn to the right
Old 09-04-2011, 06:28 PM   #9
454stepside
Re: need help
turn it as far to the left as you can then insert the paper clip into the small hole in the front and push in there is a button in there that has to be pushed in before it will go any further to the left once that button is pushed in turn to the left and pull out it can be a pain sometimes to get it out but just have patience and it will come out for you
Old 09-04-2011, 06:29 PM   #10
454stepside
Re: need help
also you might need to screw the bezel back on if you havent already done that
