Old 09-03-2011, 11:48 PM   #1
81c10steps
Fuel not going past pump
I just recently put in a small block in my 81 pickup and the fuel pump on it wasn't working. So I had a Holley mechanical fuel pump laying around and I installed it. Tried to start it and nothing. Fuel is getting to the pump but stops there. What could be the problem?
81c10steps is offline   Reply With Quote
Old 09-04-2011, 08:37 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Fuel not going past pump
Fuel pump pushrod?
Old 09-04-2011, 01:00 PM   #3
njlimbaugh
If one of the valves is stuck open from sitting around, it won't pump.
njlimbaugh is offline   Reply With Quote
Old 09-04-2011, 01:08 PM   #4
camshaftgsxr
camshaftgsxr's Avatar
either the cams pump lobe is worn off or the push rod is too short or... time for a new pump.
camshaftgsxr is offline   Reply With Quote
Old 09-04-2011, 02:00 PM   #5
tucsonjwt
Wrong pump for your truck? Check application chart?
tucsonjwt is offline   Reply With Quote
Old 09-04-2011, 02:19 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Could be the fuel pump pushrod is not working right. If you can find an electric pump try that and make sure you don't have any other issues your dealing with.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
