09-05-2011, 07:57 AM | #1 |
Is this an Eaton?
Help me ID please
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
09-05-2011, 09:35 AM | #2 |
Re: Is this an Eaton?
looks like it from pic, should be 8 lug, and one axle is longer than other. very tough, used in rock crawling buggies some. mostly found in 3/4, 1 tons.
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
09-05-2011, 11:57 AM | #3 |
Six in a row makes it go...
Sure enough.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-06-2011, 03:59 PM | #4 |
I had a Eaton in my 72 3/4 ton 4x4. Every time I made a right turn it would snap my neck and bark the right rear tire and it was 33 inches tall tire. I sent it to three different shops and they all said the axel was fine.
I swopped in a Dana 60 with a limited slip and the truck drove so much better. I couldn't believe a axle could make that much difference in the manners of the truck. |
09-07-2011, 12:42 AM | #5 | |
60-66 Nut
Your Eaton likely had a Detroit Locker in it. They are a fairly aggressive locker, that will pop and jerk when turning corners. That was a fairly common installation in these Eatons.
