Old 09-05-2011, 04:12 PM   #1
silverbullet01
'84 1/2 ton 2wd, '74 350 interceptor questions
hey guys, i've got a '84 chevy, running a TH350 and 273 rear gear, my motor is a '74 350 police interceptor, im running 882 heads, steel intake, and manifolds. i just put new head gaskets in it and intake the gaskets, the head gasket on the drives side between cylinders 3 and 5 was missing a piece 1/2 an inch big and was skipping and spark knocking. i changed it, and the truck worked great for about 2 days and is now skipping and smoking. a guy told me its probably got a broken ring, what do you think? this winter i have a set of .30 over pop up pistons, a factory GM aluminum dome, and i plan to get a cam and lifter set to put in it, nothing insane, but something with a rough idle. i also plan to switch it to a bull low 4 speed, any one have any ideas what it would make for horse power?
silverbullet01 is offline   Reply With Quote
Old 09-05-2011, 06:47 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: '84 1/2 ton 2wd, '74 350 interceptor questions
Basic things like headers, an upgraded ignition (MSD is popular and works well), and a good tune on your carb should bump HP up a little. Sounds like you have a good starting point, just make sure you get the correct-strength valve springs when you do your cam and lifter set. Roller "anything" will typically help in power too, but not a lot. It's only once you have roller "everything" that it will be noticeable, IMO; less friction = more usable power. Just some food for thought. It all depends on how much of a budget you have.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
