![]() Join Date: Aug 2001
What do you think it weighs?
70 Longhorn 3/4 ton with a 455 olds engine?
79 K10 77 MGB 79 Kawasaki KZ1000 |
![]() Join Date: Jun 2003
Re: What do you think it weighs?
My best guess .... 4300 lbs.
72longbed |
its all about the +6 inches
sounds pretty good to me.
You are leaving out a LOT of weight increasing or decreasing info... steel or alluminum wheels cast iron intake, or aftermarket headers, or manifolds A/C or non Good bed wood, rotted and missing wood, or plywood? A lot of variables... but a good guess is a tick over 4000 |
Steel wheels. don't know the bed condition yet. most of the ac equipment is still there. Not sure about the intake but guessing its cast iron.
My Tundra will haul home 1/2 tons with ease. Just checking weight differences. i would guess this is about 1,000 pounds more than a 1/2 ton? I may use my 67 3/4 ton or 70 1 ton to haul this one home.
Roadtrip!
![]() Join Date: Feb 2003
4421 lbs. I would guess maybe only about 500 lbs heavier than a similar 1/2 ton.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I agree with Eric, probably only 500 pounds more than a half ton.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
my old short/fleet with a small block and aluminum wheels/intake, headers & and aautomatic trans, weighed 3950 if memory serves.
4000 pounds is a good guess for the average 67 - 72. |
~Rest In Peace~
with or without wife
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Mine weighed in at 4400.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
Just had my '68 C30 "short" dually weighed..... (4400) on the button.
The longhorn w/out the heavy 455 is probably 4200-4300, add the 455 and I'd put it at 4375. |
My 67 C30 "short" dually weighs 5600 with no driver. I have a 292, PTO 4-speed driving a hydraulic pump/cylinder/tank for the flat bed that has 4' sides and doors on it.
... like I said earlier .... 4300 lbs. Take it to the scales ... weigh it ... and send me my prize.
#13 |
#14 |
LOL.....i havent picked it up yet. hopefully sunday. if not, then next weekend.
#15 |
Fabricate till you "puke"
Mine goes 4240,less driver, & about 1/2 tank of fuel.....she pretty stripped tho! 4" chopped top, still missing the door glass & regulators,no heat or AC,no carpet or matting & a couple lite bucket seats,no front inners, & alum heads/intake.....also 1/2 ton suspension. Id bet that you tip the scales tween 46-4800.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
