Old 09-05-2011, 05:09 PM   #1
grs
Cross member swap parts
What parts on this 69 will work on my 87? If none then my son is taking it to a show to sell.
grs is offline   Reply With Quote
Old 09-05-2011, 05:41 PM   #2
SCOTI
SCOTI's Avatar
Re: Cross member swap parts
It would swap into your 87, but, the parts on the 87 are technically 'better'. There's really no reason to swap unless something on the 87 is damaged from collision.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-05-2011, 07:10 PM   #3
grs
Someone cut the steering stops on the lower a-Arms off of my 87. I was wondering if the a-arms on the 69 would go on the 87.
Old 09-05-2011, 07:14 PM   #4
SCOTI
SCOTI's Avatar
They would physically swap but the steering stops were different between drum/disc brake front ends. If you wanted the correct steering stops for your disc set-up, I'd use later model a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-05-2011, 09:27 PM   #5
grs
