Old 09-05-2011, 06:45 PM   #1
smokinstang70
smokinstang70's Avatar
raising side mounted gas tanks
I have a 84 GMC with a 3" body lift and I really want to raise the side mounted fuel tanks on both sides if possible. Has anyone attempted that before? Is there a kit for it? Thanks in advance guys.
"Love Affair" Build Thread
smokinstang70 is offline   Reply With Quote
Old 09-05-2011, 07:21 PM   #2
BIG V
Re: raising side mounted gas tanks
pull them off the frame, drill the holes 3 inches higher on the frame rebolt on. If they are over the framne and you cant redrill weld a plate 2 inches tall on top of the frame drill this new plate.. done sorry no kits out there
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 09-05-2011, 08:54 PM   #3
RAYZDUP85
i unbolted mine, raised the bracket up until one of the bottom bracket holes lined up with a top hole in the frame and drilled the remaining holes needed. it raised approx 2 inches or a little more'
RAYZDUPNCREWZN 1985 CCSB 4X4
RAYZDUP85 is offline   Reply With Quote
