09-05-2011, 08:32 PM | #1 |
Found this in the weeds, what year is it?
Hey guys,
I ususaly hang out on the 60-66 side of the board. I recently ran across this 69-70 truck and was wondering if anyone could tell me what year it is, or any other things you might notice. Also, were there different trim levels avalible? It looked like it has rust in the rocker channels, and then some rust in the cab below the roof on the passenger side (maybe a mouse got in there and rusted it out). How difficult would it be to replace that part of the roof? I was checking out "project No-life" on the project board and this blue truck doesnt look to have as much trim as the No-Life project. Does that mean it is a different year, or just a different trim package? I only snapped one picture because I didn't want to get shot. And here is where I played around with MS PAINT: |
09-05-2011, 08:40 PM | #2 |
Re: Found this in the weeds, what year is it?
Looks to be a 70 by the innner grill division. dont know about the trim levels.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
09-05-2011, 08:42 PM | #3 |
PROJECT 7DEUCE
That is a great looking truck as long as the area above the windshield is not all rotted out.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-05-2011, 08:59 PM | #4 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
09-05-2011, 09:16 PM | #5 |
It did look like there was a little rust above the windsheild. This doesnt look easy to repair. I was thinking about finding the owner and making an offer on it, but I don't want to bite off more than I can chew as far as a project goes. I would just fix it mechaniclly and drive it.
09-05-2011, 09:23 PM | #6 |
That's a 70 grill, no doubt.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
09-06-2011, 12:12 AM | #7 |
RAT1968 '68 Cab/'71 Parts
Here it is with a little work done on it.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-06-2011, 01:27 AM | #8 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-06-2011, 06:42 PM | #9 |
AWESOME FIND, now.... go find the guy and ask him if he will sell it to you and good luck on that.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
09-06-2011, 08:54 PM | #10 |
Looks like the rocker panels are gone below the door, If I were you check out the floorboards real good like from underneath and also the cab corners. You might also want to open the hood and look back at the firewall on each upper side (if your looking at the firewall look at it all the way across the firewall at the top look for RUST) and see if you can see any rust. Check out the passenger side inner fender at the front under the battery tray to see if there is rust down there as well. I would say look down inside the Cowl Pannel as well to see if there are any holes in duct plenum (Cowl Panel is the panel right behind the hood with the slits in it). I hope you dont find much rust and also look at the bottom of the doors as well for rust. Take a flashlight and some clothes that you dont mind getting dirty. Its best to know what your getting yourself into before you start a project. Good Luck,
JRBECK64 P.S. Check out the cab supports as well, they basically hold the floorboards up from underneath. |
09-06-2011, 09:08 PM | #11 |
Not sure about all that - but too bad it's a short bed because it looks like it has original bed rails on it!
Which aren't easy to find (for lwb anyway). You took them off in your editing! No way - those are too original to be removed~!
project: "my happy mess" |
09-06-2011, 10:07 PM | #12 |
Don't blame him. Blame ME. *I* took them off on MY photoshop. Not jrblanke.
09-07-2011, 02:17 AM | #13 |
Not like that. I meant all as in all posts preceding mine, because I don't know either way other than the look of those rails.
09-07-2011, 10:20 AM | #14 |
It looks like the attention was being directed at that little spot below the drip rail. The surface rust on the top of the roof is no big deal, but that little bubble right at the window seal looks scary.
09-07-2011, 01:02 PM | #15 |
Thanks for the replies, I agree, the rust below the drip rail does look a little scary. I may ride back out tomorrow morning to take a look (1.5 hour drive). Before making an offer, it would be important to look it over really good as it is located in north eastern OH.
The bed rail on the other side was busted off about half way down. I am not a big fan of bed rails, but I really like how skinny these look! The reality is that I don't have a place to put it. I am moving in a couple weeks from western, PA to Raleigh, NC. I was trying to convence myself that I could bring it with me, but the legistics of the situation are going to be tough to work out. Thanks again for all the replies, I have learned a lot as far as what to check when looking at a project (big thanks to JRBECK). James |
09-07-2011, 03:19 PM | #16 |
Look through 72SWBChevy's build thread. He repaired his roof - which may be similar to what you might need to do.
Project: 72C10 "Clear Blue Sky"
