Old 09-05-2011, 09:19 PM   #1
capev86
gauge cluster illumination woes
hey guys and gals,
my 72 suburban has some lighting issues in the gauge panel. as in only the right side gauges are illuminated when i turn the lights on and both directional lights are lit constantly. i do have a tach and vac gage added. was using a 40 year old circuit board but swapped it out for a brand new one to try and fix the problem (both are clearanced for the tachometer). i have tried wiggling the plug without much luck. occasionally the whole thing lights up. anyone else have a problem like this? i'm thinking it is either a loose connection in the wiring/plug or perhaps this is an indication of a burned out bulb?
capev86 is offline   Reply With Quote
Old 09-05-2011, 10:24 PM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: gauge cluster illumination woes
Sounds like a ground problem. When I upgraded my cluster with Autometer gauges, the original ground wasn't enough, so I ran a 12 AWG wire from the back of the panel to under the column support bracket. I haven't had a problem since.
12 AWG is a bit excessive for what I'm grounding, but it works. If I had had any 14 AWG lying around, I would've used that.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 09-05-2011, 10:27 PM   #3
68gmsee
Active Member
68gmsee's Avatar
The connector contacts are very critical and can get bent or damaged when removing or installing. Be sure and check that out carefully. If you can wiggle it and make it work, then for sure there's a broke wire, land or contact.
68gmsee is offline   Reply With Quote
Old 09-05-2011, 11:05 PM   #4
Autoblueprint
Autoblueprint's Avatar
Post Re: gauge cluster illumination woes
X2...also...depending on the cluster itself...it is rather easy to plug the connector in 180 out of where it is supposed to be.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
