09-06-2011, 02:16 AM | #1 |
Negative Battery Cable
On my 66 GMC Lwb 2wd, where does the negative battery cable, from the battery itself, connect to on the engine exactly? It has a V6 351E in it. When I bought it, the cable was mounted to the alternator adjuster bolt...which from what I read, the cable should be connected to the engine itself. Thanks in advance!
09-06-2011, 02:31 AM | #2 |
Re: Negative Battery Cable
you should have it going either to the frame then from frame to engine,,, or from battery to engine to frame ,,, i grounded mine to the frame with one bolt that holds the battery cable eye hole end and then another battery cable that had a eye hole on each end ,then mounted the other end to a bolt that goes in front of the engine on one of the heads.. heres one similar to the one i bought at napa auto parts. to ground from engine to frame http://www.allbatterysalesandservice...fm/4,2700.html but the do make a ground strap like this http://www.appletreeauto.com/BRAIDED...FSJqgwodr1f4zw
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 09-06-2011 at 02:49 AM. |
09-06-2011, 03:05 AM | #3 |
here's how i did it.....but you can bolt it to engine in a diffrent spot.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
09-06-2011, 09:21 AM | #4 |
under the alternator brkt through bracket into block
09-06-2011, 10:07 AM | #5 |
You also need a ground from the cab to the frame .......
