Old 04-10-2003, 05:40 PM   #1
tmad
Angry Feeling stupid but still need help
Well it seems for all the questions Ive pestered some of you with concerning my rad. support(thanks to all who responded) and not being able to get anything to line up, It turns out I may have my cab to frame mounting hardware installed wrong. So could anyone post a pic of your 67 2wd lwb cab mounting set ups I sure could use the help. I did breakdown and order a assembly catalog but its gonna take some time to get here. thanks in advance for the help.
tmad is offline   Reply With Quote
Old 04-10-2003, 06:08 PM   #2
JHickson6
I Love This Stuff!
JHickson6's Avatar
LMC's catalog has a breakdown in it, not sure if there is an online version though, anyone wanna scan the page for him?
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 04-10-2003, 06:08 PM   #3
Custom 68
Custom 68's Avatar
I will be in need of this soon also. I bought ALL new pieces (rubber) and am not sure how it all goes together. I am still working on the frame so it hasnt been an issue yet. My old ones were so worn (didnt have any at the rad support) so... I have a chassis manual and will look there
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-10-2003, 07:13 PM   #4
72MARIO
72MARIO's Avatar
make sure your cab is square on the frame I had a big problem with mine till I figured out that the cab was not square. Also dont tighten the rear bolt in the inner fender (bolts to cab floor frame) that will mess up your body lines like crazy~! Shim the back like they did from the factory. Good luck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-10-2003, 09:29 PM   #5
pat
pat's Avatar
Go to www.lmctruck.com and request a catalog. Theyre FREE too.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-11-2003, 09:40 AM   #6
tmad
Thabks Pat I did that but was trying to get a jump on it. Gonna be awhile before I get it. Thanks again!
Old 04-11-2003, 10:00 AM   #7
MOTHERTRUCKERS
Are the core support mounts flat rubber with washers and a triagle shaped piece or tall cone shaped mounts like the cab mounts?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 04-11-2003, 10:14 AM   #8
tmad
My core supports are flat. I think Ive got them figured out Now I need to know how my cab mounts should be installed.
Old 04-11-2003, 01:42 PM   #9
Blue Beard
Blue Beard's Avatar
How much off are you?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-11-2003, 01:53 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Stupid question. Is your truck 1/2 ton or 3/4 ton? The rear cab mount hardware is different between 1/2 ton 2wd and 3/4 ton 2wd. Using the wrong mounts will cause problems even if intsalled correctly.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-11-2003, 05:27 PM   #11
tmad
Its a 67 2wd lwb 6lugs and drums allaround
Old 04-11-2003, 05:56 PM   #12
CPNE
Resident Curmudgeon
CPNE's Avatar
Then its a 1/2 ton unless frames or axles were swapped (highly unlikely). Is your kit for a 1/2 ton?
Old 04-11-2003, 10:03 PM   #13
MOTHERTRUCKERS
You have pm.
Old 04-11-2003, 10:21 PM   #14
Dads72
I used the diagram from the LCM (?) catalog to do mine.
Loosen all the bolts, but only do one side at a time to keep the cab from slipping.
Use a 2x4 with your floor jack.
My trim didn't line up the first time, so I did it again and added some metal washers.
I wouldn't tighten the snot out of the bolts, as this defeats the purpose of the rubber bushings.
You'll like it when you get done. What used to go "clunk" now just goes "thump".
Dads72 is offline   Reply With Quote
