Need help purchasing fuel lines....
I am a complete ROOKIE and trying to do frame off... and want to run the most simple lines as possible. I purchased a Boyd Welding tank with EFI and at the moment I am running a carb setup BUT I will be changing over to fuel injection in the near future.
I called inlinetube.com and asked them for the setup for my truck... however they are a 2 piece setup to be like OEM I guess with rubber hoses and junk. I dont want this... I want stainless tubes all the way and I want them PRETTY ![]() What do you guys reccomend me ordering? Since I am such a rookie should I even try bending my own? Any help would be greatly apprecaited!!
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
#2 | ||
"I ain't nobody, dork."
Re: Need help purchasing fuel lines....
You have to have some sort of rubber, or braided line in there from the frame to the pump to allow for movement/vibrations, or you will have cracked fuel lines. Doesn't have to be much... just to allow for a little flex.
There is some pretty snazzy braided lines available nowadays... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
^^^ exactly, you can do braided but its not cheap. I just got the coated fuel lines an bent them myself but there not shiny.
1969 Chevy c20(Miss Hackjob) |
its all about the +6 inches
You'll need to build your system keeping in mind your EFI plans. An electric in tank pump will be best, esp if you opt for a factory latermodel induction system.
I would recomend solid lines from the tank, and then a short section of steel braided (that can handle whatever PSI your future induction system will need) and then back to hard lines. You could save a few bucks right now and just do steel lines from the braided lines to the carb, since you'll be throwing them away later when redoing the induction system. If you just make the parts to fit todays set up, then you'll be throwing most of it away later. |
you might b better off using aluminium as it is cheaper and easier to work with compared to stainless/ aluminium can easily b polished to b shiny
th reason why there should b flexible pieces tying everthing together is to allow for the normal flexing of the frame // a hsolid hard line will develop flex cracks and eventually fail usually at the worst possible time
