Old 09-07-2011, 12:37 AM   #1
bigwheel15
bigwheel15's Avatar
Random lowering question...
I have been looking at all the different ways to lower the rear of my truck more and something raised a question, if you have a flip kit done on the rear and pull leaves out of the leaf pack wouldnt that be effectively raising the rear back up?
bigwheel15 is offline   Reply With Quote
Old 09-07-2011, 12:51 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Random lowering question...
No because the axle sits on top of the main leaf. Removing springs will lower it further and increase axle wrap.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 09-07-2011, 12:54 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
not necessary, its depends on how many leafs are in the spring pack, when I only had 3 leafs in the spring pack the rear was almost dropped 8" drop with a flip kit, then I added 2 leafs back in the pack it raised it to a 5" drop
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-07-2011, 02:01 AM   #4
cr34t3d_by_d4rkd3n
yes.if the prings had 0 sag. however the trucks weight on the one spring and the overload spring, causes about 2.5 in. far more than the 1/2-3/4in of removed spring thickness.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
