Old 09-07-2011, 07:22 AM   #1
chevykevy
chevykevy's Avatar
Tilt Column Woes
I thought I had "rebuilt" my tilt column from a 71 or 72. I have had it in the truck as I have been putting things back together for a couple months now. Went to put the steering wheel last night and after getting the wheel on discovered play, up and down. It isn't loose fore and aft. Are things just worn out? Maybe I should sell it for parts
chevykevy is offline   Reply With Quote
Old 09-07-2011, 10:20 AM   #2
bmfm64
bmfm64's Avatar
Re: Tilt Column Woes
Did you tighten the three bolts in the upper end?
bmfm64 is offline   Reply With Quote
Old 09-07-2011, 03:10 PM   #3
chevykevy
chevykevy's Avatar
I did. I am going to take it apart tonight and see if I can find the issue. Could I have not properly placed the two saw like gears that are actuated when movong the lever to adjust the location? They hold the column in place when tilting.
Old 09-07-2011, 04:15 PM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
the GM tilt steering columns have one major Flaw you use it to pull your Fat self into the truck.Thats why they don't use them like that any more.I see the fab guy using the new way and it takes a lot of the where out of the truck
stsalvage is offline   Reply With Quote
