Double 6's
got the 66 lowered with the new wheels....
and Im not impressed. There is a lot of weight in the bed, so Im hoping the rear will come up a bit. All in all, I dont like the way it looks. figures. The pic is small, Ill get bigger ones today and post.
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
Re: got the 66 lowered with the new wheels....
this was why I went with air bags in the rear, at least one can adjust it to the ride height you want and it was not that expensive -----$200.00
Seems like the front needs to come down more,but looks cool overall,probably will look better with the weight out of the back also.
![]() Join Date: May 2007
I agree, pound that front some more and watch your interest go up as the front goes down.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
It takes a little while for the front coils to settle. I would take the lode off the back and drive it over some speed bumps and then see how it looks. How much did you lower it?
![]() Join Date: Aug 2009
looks like the tires are too small too
you can cut a little off the front coils as well and come down another inch or so
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I also what to know how much you dropped it and how?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Double 6's
heres a better picture. It has a ton of stuff in the back, Im sure itll come up some. It has 82 drop spindles, and stock springs. I have a set of cut coils, but it would come waaaay down. I dont know what to do really. the rear is CPP coils, but I bought them used, but barely, but The PO didnt know how low they were. any way to figure that out?
From the look of it at least 5" drop coils in the rear?? The front doesn't look dropped at all. I'm new at this with these trucks but I took some measurements on mine today and a 2 1/2 drop spindle should put the edge of the fender just above the front wheel. But with the stuff in the back it's really hard to tell.
Registered Loser
I think the small tires make it look like the front isn't lowered.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
take all the stuff out the bed to see exactly where youre at. then drop the front 2 inches
Posted via Mobile Device |
#13 |
As far as tires go do people run stock height or generally go bigger? Would a 225/75 15 be an equivalent to a stock tire on a 63 C10?
#14 |
i like it kinda looks like a 50's gasser
